1994 RAGE 14 Steering Cable
Ebart2353
Postby Ebart2353 » Thu May 26, 2022 9:27 pm
Where can I get information on the steering cables for 1994 RAGE 14?
Thanks, Evelyn
Re: 1994 RAGE 14 Steering Cable
Postby jimh » Fri May 27, 2022 9:13 am
What information are you looking for?
Do you have the original cables on hand?
What sort of helm is on the RAGE 14?
Assuming the steering is a manual mechanical single cable system, the cable is probably a part fitted into the helm, not something separate from the helm. Inspect the helm to locate a manufacturer name and model designator.
Once you identify the helm manufacturer and model, you can measure the cable length. The OEM manufacturer of the helm can supply a replacement cable of the desired length.
