2000 Conquest 23 Paint Match for Door Frame
JPTL
Postby JPTL » Tue Aug 23, 2022 7:09 pm
Rust-Oleum Stops Rust Gloss Canvas White Spray Paint 12 oz Item #1205426| Mfr #7789-830 is a perfect color match for the aluminum door frame on a 2000 23 CONQUEST.
The paint on the aluminum cuddy cabin door frame [pm a 2000 CONWUEST 23] was flaking off as a result of aluminum corrosion under the finish. I decided that I'd repaint the frame and looked for a color that was a close match. I planned on repainting the entire frame, since the chances were one in a a hundred that I'd find an exact match in a spray can.
I beat the odds and found an exact match in Rust Oleum. I had a sample chip and compared it to Rust Oleum color samples. Canvas White looked really close. So I ordered a can.
The paint was difficult to find, but an Ace [Hardware store] in Portland Maine, had it. My daughter picked it up on her way back from the airport.
After prepping the frame, and taping everything off, I applied a coat. The match was EXACT to the e off-white color used on my model Conquest 23.
[This paint may be also a match] for trim on other [Boston Whaler boat] models.
2000 Conquest 23
Mambo Minnow
Re: 2000 Conquest 23 Paint Match for Door Frame
Postby Mambo Minnow » Sun Aug 28, 2022 3:25 pm
I removed my door frame and had the frame powder coated. Peeling paint on the frame is a common problem in these models.
