Removing Varnish Stains From Nonskid Surface.
Posted: Thu Sep 29, 2022 3:05 pm
I have a 1983 Sport 15. The gel coat is in good condition except for some spots where a previous owner did a sloppy job of refinishing the wood surfaces and dripped spar varnish on the deck.
Q1: how I can remove the stains without damaging the non-skid gel coat?
Q2: how can i repaint the non-skid?
Q3: what products are effective in removing stains from gel coat?
Q4: is there a a paint who color is close to Desert Tan that is thin enough to not fill-in the factory non-skid surface?
Note: I have no intention of applying new gel coat or repainting the entire boat, or the interior, or the smooth parts of the interior. At most I will repaint the non-skid.
Thanks for any ideas.
MORE DESCRIPTION OF WHAT STAINS ARE TO BE REMOVED
There are numerous spots (maybe 50 or so), about dime size or smaller, and several larger ones, about silver dollar size.
The spots on the smooth parts of the gelcoat remove easily and completely using acetone or toilet bowl cleaner, and scraped off with a razor blade. The spots on the imprinted, factory diamond pattern, non skid surfaces however, are down into the non skin pattern texture (down into the diamond shaped texture), making it impossible to scrap away with a razor blade. I tried a small stainless steel wire brush along with acetone and toilet bowl cleaner, but it has no effect. I wasn't very aggressive with the wire brush as I didn't want to damage the non skid pattern. I don't want to try sanding it, as that will no doubt remove the texture. There are too many to try to pick out individually with a dentists pick etc.
I saw some products advertised to remove varnish, but some look to be rather harsh and might damage the gelcoat of the non skid pattern. There are some citrus based products on Amazon, but most of the user reviews say they are ineffective.
If I am unable to remove these stains, I have thought of simply masking and painting over the non skid areas. If I do that, I don't want to use any paint with non skid granules imbedded, as that would fill in the molded in factory non skid pattern, and although it would likely prevent a slippery surface, it would look terrible in my opinion, worse than just leaving the stains.
I would much rather just remove the stains than to mess with painting it.
