1980 13-footer Restoration: 16 Questions
Posted: Tue Dec 20, 2022 1:34 pm
I've owned a 1966 13-footer 13 for the 18 months, and I have fallen in love with the boat. So much so, that a few months back, I purchased a 1980 13-footer with Yamaha 40-HP two-stroke-power-cycle engine a really great price locally in Virginia. I'm going to restore the boat to create a saltwater fishing setup. I need suggestions, advice, and opinions on the best way to restore this Boston Whaler boat.
Due to the water line and my ability to lift the stern up slightly, I believe this 1980 13-footer hasn't accumulated too much water over the years, and it should be water worthy
Here are my goals and questions for the restoration:
I want to make the boat interior functionality sound, without going overboard on a proper restoration. As an example, I don't mind the crazing on the deck.
Q1: should I paint the 1980 13-footer?
Q2: would it make sense to paint the 1980 13-footer?
Q3: what are the options for painting the boat?
I've heard of a material like RhinoLiner for interiors that while not sexy is bulletproof, strong, will last substantially longer than paint.
I want to restore the hull and hull bottom properly so there is no water in the hull for the future. I imagine the hull and hull bottom are the areas of the boat that is going to need the most work, and also where the most water will seep in.
Q4: what advice would you have for someone looking to create the longest-lasting bottom job?
Without sanding I won't know [the condition of the hull bottom[ for sure, but there appears to be very little fiberglass damage, if any, anywhere on the bottom of the boat. It's part of the reason I purchased the vessel. I will be storing the boat on trailer, in my garage, not in the water.
I also want to install a trolling motor on the front. I have a Minn Kota quick-release bracket iPilot 55-lbs-thrust motor.
Q5: will the front stepping area of the 1980 13-footer be strong enough to hold an iPilot 55-lbs-thrust trolling motor?
Q6: what can I do to further solidify the front stepping area of the 1980 13-footer?
Q7: what are the ways I could install a 55-lbs-thrust Minn Kota iPilot trolling motor so that the hull stays structurally sound over time with the weight of the trolling motor on it?
Q8: does the hull of a 1980 13-footer need reinforcing in the front stepping area before a trolling motor can be installed?
I want the hull to have balance weight for easy on plane. There is a large under-seat fuel tank that came with the boat.
Q9: if the 1980 13-footer has two batteries in stern, one for starting the engine and the other for the trolling motor and electronics, would it make sense to move the fuel tank underneath the first bench closest to the bow?
Q10: is cleaning the existing fuel tank recommended so that a new fuel tank is not necessary?
I want to restore the Norman pin and other metal components.
Q11: what are the most effective methods that have been found by others to restore a Norman pin and other metal components?
Q12: what should be done to the back brackets to give then sufficient structural integrity to allow for towing a tube?
I bought two self-leveling trim tabs.
Q13: should self-leveling trim tabs be installed on a 1980 13-footer?
Q14: is installation of self-leveling trim tabs excessive for a 1980 13-footer?
I want to limit any possible water seepage into the hull.
Q15: for a rookie restorer, what are the areas and what are the tactics to use that will prevent water seepage into the hull and improve the long-term health of the hull?'
I plan to make sure the rub rail is sealed and to caulk on areas where pins go in the boat.
I want to make the boat dog ready, if there's even such a thing. I'm planning to get a dog, one that loves the water, and will be trained to join me on the boat, late in 2023.
Q16: what should be done and what should be added to make a 1980 13-footer ready for a dog?
You can see the boat at this URL
https://docs.google.com/document/d/1ET5ysDgzgmAdUZp0IbP9htSfdfc4DL5T2IeqnPPfNcE/edit?usp=sharing
Please don't feel the need to respond to every question or idea, only the ones you feel compelled to answer and arre qualified to provide your personal perspective. I will greatly appreciate help from the community.
If there's anything you think generally speaking I am missing, that I should think about as I get ready to start on this project in the spring, please let me know. Look forward to soaking up the experience from others as best as I can, and teaching myself a thing or two in the process.
--Ben
--Ben
