Re: Replacement Fuel Tank: Coat or Leave Raw Metal
Posted: Sat May 17, 2025 8:52 pm
In believe the original fuel tank in my 1998 17 Outrage II has a leak (or several leaks). One is at the outer rear port side, side and bottom of corner. I had a new tank fabricated by Alloy Metal Works in Farmingdale, New York.. They were super easy to deal with, had the OEM drawings, and gave great service.
Before the new tank goes in, I'm trying to decide if the newly fabricated fuel tank should be left raw [metal of some unspecified metal, but most likely aluminum of some unspecified alloy].
Q1: should the new metal fuel tank I just had custom fabricated [from some unspecified metal of unspecified composition] be install as-is or some [unspecified] coating applied to it before installation?
Online [many various] opinions can be fiund. The folks at Alloy Metal Works don't do coatings. Their opinion seemed to be that if anything is wrong with the coating, it will trap moisture and accelerate corrosion.
Other people swear by a coating which seems to range from epoxy bottom paint to coal tar epoxy.
Alloy Metal Works said if it gets coated, use an etching primer, possibly zinc chromate.
I'm not doing the installation.
The shop says they will coat it if I want and are waiting on direction from me. The boat is trailered and covered.
The fuel tank that was removed appeared to have a coating on it, and a few spots it had bubbles. The coating was not on the area that leaked, although that may be due to scraping while searching for the leak.
