BAYSTAR Hydraulic Steering Problems
Posted: Sun Aug 03, 2025 2:30 am
My 2000 Alert 17 (special service classic Montauk), has the BAYSTAR model hydraulic steering. A few years ago I refreshed the [hydraulic fluid] and bleed (air from the system].
In the 2025 season the BAYSTAR steering has begun a behavior that is described in the troubleshooting section of the documentation: it takes way too many turns to go lock to lock. Only it’s butter smooth. Not stuttering like you might get with air bubbles and a bad bleed. The documentation says that this is probably due to fouling of the internal valving in the helm.
Q1: do readers agree that the cause of having too many turns lock-to-lock is due to fouled internal valves in the helm?
Q2: or, do readers believe the cause of having too many turns lock-to-lock is due to [air in the system, as a result of a] bad fill and bleed?
-Peter
-Peter
