1990 Montauk 17 Propeller selection
Posted: Sun May 03, 2026 6:40 pm
Hello. I bought a 1990 Montauk 17 with a 2019 Mercury 90 EFI with the standard gear case (2.07:1). The motor is mounted one hole up. WOT range is 5000-6000.
The previous owner was an older gentleman who didnt really care to go fast, though he had repowered with the current outboard. He sold me the boat with two propellers.
Performance of the three propellers has been has follows, and none I believe are the “right” prop for the boat:
Turning Point 17 pitch: 38-MPH at 5400 RPM with two people, 10 gallons of fuel. Fully trimmed out -
Black Max 15 pitch: 38 MPH at 6000 RPM with two people, 10 gallons of fuel. Hit RPM limiter well before WOT
Black Max 19 pitch: 41 MPH at 5250 RPM with one person and 8 gallons of fuel. Boat handling was very weird with this propeller, best I can describe it is squirrelly and unsettled. I couldn’t trim up very much without the propeller blowing out and the engine speed immediately jumped but boat speed didn’t. I trimmed down and engine speed dropped and boat speed increased.
Before I go propeller hunting I figured best to poll the general knowledge of this forum. I can take information gathered here to a local propeller shop to try to work out what is best.
I am thinking of either going for a Black Max three-blade 16 or 17 pitch or a Spitfire four-blade 15 or 17 pitch (and likely the aluminum one, not sure I am ready to fork over for a steel propeller, though there is a 17 pitch used one near me for $450).
I actually bought two used props: a 17 pitch Black Max and also the 15 pitch Black Max since they were a good deal. The 17 pitch broke a blade tip when i went to install it, and come to find out it had been repaired.
My performance goals:
- Get the WOT engine speed to be between 5800-6000 when lightly loaded.
- Max speed is less important, I don’t feel like I need to go much more than 40-MPH based off my use to date.
- Accelleration is more important. I will be pulling kids on a tube. I’ll probably hold on to the Black Max 15 pitch for those times since it spun up well.
Thanks for your help
- Black Max three-blade 13-inch x 19 pitch, and I believe this is what the boat was re-powered with. It wasn’t on the boat when I purchased the boat. The seller said he had hit something with it and had it repaired, but he was just using the spare he had bought instead.
- Turning Point Hustler four-blade 13.25-inch x 17 pitch, which came on the engine.
- I have since borrowed and tried a third propeller which is a Black Max three-blade 13.75-inch x 15 pitch.
