13' Engine Mounting Height Recommendation - 25hp
Posted: Sat Jul 15, 2017 4:27 pm
I'm selling my 25hp 4-stoke Yamaha long shaft to a friend with an older 13' with a 15" transom. His Whaler already has a two piece lift bracket installed similar to the one linked below.
http://continuouswave.com/whaler/cetacea/cetaceaPage56.html
Engine is tiller steer and has the clamp on bracket so once mounted any height adjustment will take more effort than normal hole up or down. A transom thick piece of two-by or plywood will be bolted to the forward side of the lift bracket for clamping engine and to attain final mounting height. Do you have an estimate for how far above hull bottom the cavitation plate should be for best performance. I also noticed the drain is rather close to bottom, about where should a 13's drain normally be in relationship to surface of the water when a well balanced boat is at rest. If anybody has same boat/motor combination and has a prop recommendation that would also be appreciated.
Thanks in advance for the advice you may offer.
