180 DAUNTLESS Jack Plate
Dauntless
Postby Dauntless » Tue Aug 11, 2020 5:59 pm
For my 180 DAUNTLESS I am considering using a Bob’s 4-inch hydraulic jack plate to improve performance improvement and enable the boat to run in shallow water.
[To anyone who has run a Bob's 4-inch jack plate on a 180 DAUNTLESS:] Are there any problems with this set up?
Will adding the jack plate cause cause porpoising?
BACK STORY: Ten years ago I bought a Montauk with a 35-MPH top speed. Everyone here said get a jack plate and a Stiletto prop. I got that prop and a 4-inch manual plate; the boat was completely transformed. Top end was 42-MPH. I saw no negative affects. I just sold that boat and bought a 2006 180 DAUNTLESS 180 with a VERADO 150. The 180 DAUNTLESS runs 42-MPH at 6,200-RPM with three aboard.
[Moved to PERFORMANCE forum.--Moderator]
Masbama
Re: 180 DAUNTLESS Jack Plate
Postby Masbama » Tue Aug 11, 2020 9:59 pm
I had a 1999 Dauntless 18 with a jack plate. It came with the boat so I don’t know how the boat handled before the jack plate.
That DAUNTLESS 18 boat did porpoise at times. I found by raising up the engine and keeping the trim down eliminated the porpoising. The jack plate also was great for getting in and out of shallow water.
Dauntless
Re:180 DAUNTLESS Jack Plate
Postby Dauntless » Tue Aug 11, 2020 10:56 pm
Masbama wrote:I had a 1999 Dauntless 18 with a jack plate...
Thank you for answering. What set back distance was the jack plate?
Masbama
Postby Masbama » Wed Aug 12, 2020 8:54 am
I can’t remember exactly so I am guessing it was 4 to 5 inches.
