13-footer with 40 HP
Posted: Fri May 07, 2021 1:56 pm
by joemahoney79
Q1: What propeller is the ideal propeller for a 1988 SPORT 13 with a 1988 Yamaha 40-HP two-stroke-power-cycle engine with three cylinders?
I have tried the various prop calculators.
I am prepared to do a full RPM test.
I hope [some advice on a propeller contributed in reply to this post] might save me time.
Re: 13-footer with 40 HP
Posted: Fri May 07, 2021 3:00 pm
Q2: What is the GEAR RATIO of your engine?
Q3: What is the manufacturer's recommended full-throttle engine speed range?
Q4: Do you have a TACHOMETER for the engine?
Q5: Do you have a means of measuring BOAT SPEED?
Q6: Do you have any data about the boat performance?
Q7: What will be the total weight of the boat, engine, gear, and passengers for normal operation?
Posted: Fri May 07, 2021 3:06 pm
joemahoney79 wrote:I have tried the various prop calculators.
A propeller calculator is not an oracle. It just computes a parameter based on other parameters you give as input.
A propeller calculator cannot be used to select a propeller for a particular boat and engine combination until the boat speed at full throttle has been estimated or calculated or taken from observations made by others, until the engine speed at full-throttle is known, and until the gear ratio of the engine is known.
Posted: Fri May 07, 2021 3:15 pm
From owners with the Yamaha 40hp and the classic 13' Sport, the list of recommended props include:
10.5 x 13 aftermarket
10.5 x 12 Yamaha Performance/Turbo Hot Shot
The engine should be mounted "1 hole up" so the top engine bolts are in the 2nd hole counting down from the top.
As for performance, running solo, light, no gear, smooth bottom paint, on calm water, should see 34-36 mph.
Posted: Sat May 08, 2021 7:51 pm
by joemahoney79
@Phil T thanks for the help. When you say 1 hole up on the engine mount wouldn't that mean that bracket would not bottom out on the top of the transom? The boat originally came with a smaller Honda 4 stroke and the bolt holes are totally different. I am filling the old holes with stacked teak plugs and filling/fairing. Going to be drilling new holes to mount the Yamaha.
Posted: Sat May 08, 2021 8:40 pm
