1984 SUPER SPORT 15 Yamaha F70
Recommend a propeller for a 1984 SUPER SPORT 15 with Yamaha F70.
Re: 1984 SUPER SPORT 15 Yamaha F70
Owners of Super Sport 15 boats with an F70 have tested many make and model propellers. Here are their recommendations.
13 x 16 PowerTech SCD3 (17" if running light on flat water)
13.25 x 17” Turbo 1
*Note size is for the make and model listed and is not transferable.
Presumes engine is mounted two-holes up.
13.25 x 17” Turbo 1
Thanks, my friend.
[Moderator's note: moved a new thread begun on precisely the same topic as this thread to this original thread. Rewrote the question from the new thread to be clear and have the necessary information contained in the question:]
For a 1984 SUPER SPORT 15 with a Yamaha F70 long-shaft engine, which engine mounting height is recommended?
[Please do not start a new thread for every new question you want to ask about the set-up of your 1984 SUPER SPORT 15 with a Yamaha F70--jimh]
Re: 70 hp yamaha
Ideal mounting height is for the top bolts are in the third hole counting down from the top.
[Moderator's note for the OP in this thread: the engine mounting described above is called a two-holes-up mounting. Please read:
ENGINE MOUNTING HEIGHT
https://continuouswave.com/forum/viewto ... ?f=7&t=739
The above article was written very carefully with the goal of NOT HAVING TO EXPLAIN engine mounting height description over and over and over.]
