2003 130 SPORT 40-HP
Posted: Mon Aug 04, 2025 11:28 am
Q1: what is the expected maximum boat speed for a 2003 130 SPORT with a 40-HP two-stroke-power-cycle engine?
BACKSTORY
In Spring 2025 I bought a 2003 130 SPORT with a Mercury 40-HP two-stroke-power-cycle engine. I installed new spark plugs and a new water pump.
With only me (220-lbs) aboard, the maximum boat speed is 27-MPH (measured by GNSS receiver) at 5,500-RPM. I am not complaining, and this is fast enough for the boat’s intended purpose, but people say these boats do 40-MPH all day long.
I am concerned that this 2003 130 SPORT is heavier than it should be. Before I begin to look for wet foam, and I want to know:
Q1 (repeats): what is the maximum boat speed a 2003 130 SPORT [with a 40-HP 2-cylinder Mercury two-stroke-power-cycle engine] has achieved?
The boat sits with the red line a little above the water line, and it is even all the way around.
The engine peak dry cylinder pressures is greater than 90-PSI on both cylinders.
The engine vibrates a little. I figure this vibration normal for all two-stroke-power-cycle engines.
Q3: could the present low boat speed and the vibration be caused by a problem with the carburetors?
Please offer advice.
BACKSTORY
