Update on 2008 SONAR Installation and New Plans
Posted: Sat Jun 08, 2024 11:11 pm
I am about to replace the through-hull SONAR transducer on my 1998 OUTRAGE 23 that I installed in 2008, 16-years ago. The new SONAR transducer will fit almost flush to the hull bottom and will be a CHIRP model with a power rating of 1000K [probably means 1,000 Watt]. It should fit the existing hole.
I will use "5200 goop" to loosen the mounting of the current transducer.
BACKSTORY
In 2008 I wrote an article about my plan to drill a 3.75-inch-diameter hole in the putty box on my 1998 OUTRAGE 23 after the ten-year hull warranty expired in order to install a FURUNO bronze SONAR transducer with a 20-degree tilt angle that would mount flush to the hull bottom (and thus not interfere with the boat being loaded on a trailer). The FURUNO through-hull SONAR transducer was part of a NavNet system on my boat that worked "great."
FUTURE PLANS
I will be replacing the current FURUNO SONAR with a new FURUNO 12-inch touch-screen System-3 model.
I will add a FURUNO satalite up top for a new FURUNO autopilot.
I have a RADAR on order that uses Doppler.
SECOND SONAR
I also have a transom mounted SONAR transducer that works with a GARMIN SONAR that has as 12-inch display.
ADVICE
Use a through-hull SONAR transducer if you want to read the bottom at speed.
BACKSTORY
FUTURE PLANS
SECOND SONAR
ADVICE
