RAYMARINE NMEA-0183 Devices
Posted: Sun Dec 15, 2024 10:51 am
I believe I once read an article that said Raymarine used some proprietary devices or methods of connecting using NMEA-0183 devices.
[Separated from another thread on a somewhat similar topic regarding NMEA-0183 interconnection of devices--Moderator]
Re: RAYMARINE NMEA-0183 Devices
Posted: Thu Dec 19, 2024 11:38 am
Jefecinco wrote:I believe I once read an article that said Raymarine used some proprietary devices or methods of connecting using NMEA-0183 devices.
Perhaps you are confusing the Raymarine SeaTalk NG (for "Next Generation" of SeaTalk) variety of NMEA-2000. The Raymarine SeaTalk NG communication uses essentially the same protocol as NMEA-2000 but implemented the wiring using different electrical connectors.
Raymarine wrote:SeaTalk NG is Raymarine's cabling system used to carry NMEA 2000 data. SeaTalk NG cabling offers several benefits when networking Raymarine instruments and autopilots.
They also mention:
Raymarine wrote:SeaTalkng is a proprietary extension to NMEA 2000 and the proven CAN bus technology. Compatible NMEA 2000 and SeaTalk / SeaTalk2 devices can also be connected using the appropriate interfaces or adaptor cables as required.
See: https://www.raymarine.com/en-us/our-products/networking-and-accessories/seatalk-ng-and-nmea-2000
Raymarine also makes some protocol converters that attempt to translate certain SeaTalk NG (i.e., NMEA-2000) datagrams into corresponding NMEA-0183 sentences.
See:
https://www.raymarine.com/en-us/our-products/networking-and-accessories/seatalk-ng-and-nmea-2000/seatalk-ng-to-vhf-nmea-0183-converter-kit
and the installation manual (linked below) at Page 10.
This particular product was a one-way translator. The product was able to convert some SeaTalk NG (NMEA-2000) parameter group data into a limited set of NMEA-0183 sentences.
For more details about this converter, consult its installation manual, "NMEA 0183 to SeaTalkNG Converter Installation instructions 87256-1-EN.pdf", available at
https://raymarine.app.box.com/s/rvhycb6 ... 3240336057
Note this converter device appears to ONLY permit the SeaTalk NG device (which could be a GNSS receiver or a multi-function display with an integral GNSS receiver) to send POSITION DATA to the NMEA-013 device (which is presumed to be a DSC radio).
