Seeking a clean Outrage 22 vintage 1989-1993 (94??) with:
- Welded bow rail
- Full width splashwell dam
- Glass gunwales
- NO bottom paint
Flexible on power, console, trailer, location and timing. Ideally freshwater only (upper midwest???). Looking to move up from my Outrage 18.
Generally located in San Francisco. Will be in Minnesota for the next week.
Thinking of selling your boat? Have a neighbor with an unused 22? Just like to talk Whaler? Drop me a line!
Thank you,
Sean
irishcreamer@gmail.com
WTB Outrage 22 (1989-1993)
Re: WTB Outrage 22 (1989-1993)
Sean - Good to see you back.
irishcreamer
Back in MN this week between Brainderd and Bemidji...any leads appreciated.
IC
IC
irishcreamer wrote:Back in MN this week between Brainderd and Bemidji...any leads appreciated.
IC
Did you look farther down the MARKETPLACE page? That's the best classic 22 I've ever seen.
Tim
irishcreamer
Thanks, Tim.
Assume you refer to LakeGenevaWhaler's 22 full transom? That is indeed a clean boat. However, I am looking for an open transom.
Yes, that's the one I was referring to. I did not see that you were looking for an open transom - is that what "full width splashwell dam" implies?
irishcreamer
Yes the full width splashwell dam is one of the open transom layouts.
In MN through the weekend...
IC
IC
I have an outrage 22 that I might be willing to part with. Give me a call. Located in Michigan. 847.347.2699.
I am in Eureka, CA, asking 10k. email me for pics at jedborneo@yahoo.com
1980 Outrage 21 (21’ 4”) “Banana” Hull
1981 Evinrude 200 outboard with hydrofoil (runs but needs rebuild)
Apollo 4 blade stainless main prop w/ extra shear kit
15 hp Johnson outboard kicker with remote steer
galvanized twin axle trailer w/ lifetime twin-roller jack
Garmin GPSmap 498 chart plotter dash mounted w/ transom transducer
Garmin echo 550c fish finder dash mounted w/ transom transducer
ICOM IC-M302 marine radio dash mounted w/ antenna
replaced 40-gallon belly fuel tank with in-tank gauge and dash gauge
twin 15-gallon stainless auxiliary fuel tanks (mounted beneath gunwales)
new steering cable
leaning post w/ storage compartment
replaced all gauges on center console
3 stainless rod holder tubes and 2 steel rod holders
keel guard and bow guard
2 spare water separating fuel filters for remote filter mount
replaced wooden base of center console with aluminum
6 rod side console mount
wash down pump
dual batteries
green boat cover (minor tears)
replaced bow running lights
new electrical fuse panel and electrical switch panel
Scotty downrigger w/ 12 lb weight and 300 ft of 200# braided line
Danforth anchor (releasing style) w/ 300 ft of anchor rode
2 inflatable fenders
new steering cable
wash down pump
dual batteries
Sean.
You would absolutely love Tony Korigalos' 22. I know I misspelled his last name. Greek guy. My buddy bought his former 27 Montauk "Red Dot."
He had his 22 for sale a bit back. He wanted 40 or so for it maybe 6-8 years ago. Not sure if it sold. I saw it at the dealership new when I picked up my 17.
The entire boat was grey and black, like my 17.
If I remember correctly, his 22 was a Guardian, 1998.
Single merc 225 and a full transom well. First I've seen ever.
There were 2 other 22's delivered, both to commercial fishermen, but standard splashwell.
FISHNFF
FISHNFF
irishcreamer
Appreciate the responses. Still in the market and looking for a later model year 1989-1993 Outrage 22.
FISHNFF - Thanks, Brian. I know Tony and have seen many pictures. Sweet ride however seemingly out of my price range.
kookadala - Thank you for highlighting your boat. Those banana hulls are great however I am really looking for a late 80's model Outrage 22. Good luck with your sale!
Outrage - Thanks again for reaching out. I am looking for a late 80's model.
Best Regards,
IC
Best Regards,
IC
irishcreamer
*bump*
Will be in the market again this Spring for a late 80s / early 90s Outrage 22 center console. If you have or know of one that may be for sale please let me know.
Thank you,
Sean
Thank you,
Sean
irishcreamer
I am still in the market for a 22...
irishcreamer
Found my 22 [thread closed]
