Recent Approvals for AIS Transponders
Postby jimh » Tue Nov 27, 2018 12:57 pm
Recent USCG Approvals of AIS Transponder Devices for CLASS B
By Date
DATE        MANUFACTURER    MODEL AND TYPE
05.25.17 ALLTEK WideLink B600/B600W Class B SO
02.08.18 RAYMARINE AIS700 Class B SO
03.16.18 em-trak B100 Class B SO
04.10.18 SRT Iris Class B SO
04.10.18 SI-TEX MDA-5H Class B SO with Splitter
06.18.18 em-trak B300 Class B CS
06.18.18 em-trak B330 Class B CS
06.18.18 em-trak B350 Class B SO
06.18.18 em-trak B360 Class B SO
06.18.18 SRT Neon II Class B SO
06.18.18 SRT Neon II+ Class B SO
06.20.18 Watcheye B Pro Class B SO
06.18.18 SRT Neon II Class B CS
06.18.18 SRT Neon II+ Class B CS
06.18.18 em-trak B100 Class B CS
06.20.18 GARMIN AIS 800 Class B SO
06.21.18 SRT Iris Class B CS
07.25,18 SRT Iris+ Cass B SO with WiFi
07.25.18 SI-TEX MDA-5 Class B SO with Splitter with WiFi
08.20.18 JRC NTE-380 Class B CS
This list was compiled from the UCCG website at
https://cgmix.uscg.mil/Equipment/EquipmentSearch.aspx
by searching with the APPROVAL SERIES NAME set to AUTOMATIC IDENTIFICATION SYSTEM CLASS B - 165.156
Re: Recent Approvals for AIS Transponders
Postby jimh » Mon Dec 03, 2018 11:35 am
Once an AIS device is approved by the USCG, it can then be approved by the FCC. Finding information about approved devices from the FCC is more difficult, as there thousands and thousands of devices which must be approved by the FCC. The FCC has a website that allows searching of approved devices. See
EQUIPMENT AUTHORIZATION SEARCH
https://apps.fcc.gov/oetcf/eas/reports/ ... Search.cfm
To facilitate searching for a particular manufacturer, it is very useful to know the manufactor's "Grantee FCC ID" code. Here is a list of those codes for several manufacturers of marine electronics, particularly radios and AIS transponders, which will greatly improve searching the FCC approved products database:
FCC ID Codes for Marine Electronics Companies
    SRT Marine Systems = UYW
    Yaesu Musen (Standard-Horizon) = K66, AKH
    Navico = RAY
    Lowrance (some limited products)= D6N
    Alltek Marine Electronics = WZ7
    Garmin = IPH
    Uniden = AMW
    Vesper = YJD
    Icom = AFJ, CFE
    Raymarine = PJ5
Other criteria can be used to narrow the search results. Useful parameters for improved searching may be:
    FINAL ACTION DATE RANGE; set a date range limit to more recent dates to find the latest approvals
    APPLICATION PURPOSE: set to "Original Grant" to find the initial device approval
    EQUIPMENT CLASS: set to GVH-Part 80 VHF Transmitter (GMDSS); (results unpredictable)
