Determining Water Content in Unibond Hull
Michele
Postby Michele » Fri Dec 30, 2022 6:15 pm
I may buy a 1985 Super Sport. I want to make sure it's not waterlogged.
Q1: Other than weighing this boat is there any other way to measure how dry or wet the core may be?
Re: Determining Water Content in Unibond Hull
Postby Phil T » Sat Dec 31, 2022 1:16 pm
[To determine if the hull may have acquired water in the interior of the Unibond hull,] look for:
  • screw holes
  • rust stains from transom eyes
  • weeping from drain tubes and engine bolts.
Regardless of the bottom paint, can you tell where the grime line is on the transom and the aft quarters.
This is a highly sought after model. As long as the engine is not a brick, the pricing is reasonable.
Postby jimh » Sat Dec 31, 2022 5:50 pm
Michele wrote:Q1: Other than weighing this boat is there any other way to measure how dry or wet the core may be?
Your question is one of the most frequently asked questions. An answer has already been prepared. See the FAQ at Q3: Is there water in a Unibond hull?
Michele
Postby Michele » Sun Feb 05, 2023 10:16 pm
Thanks for the info
