190 MONTAUK Re-power SUZUKI 140BG
kjang
Postby kjang » Wed Mar 29, 2023 5:55 pm
I decided to re-power my 190 MONTAUK with a SUZUKI 140 BG. The new engine is on order. My decision was based on engine weight, cost, and anticipated performance. My initial thought was to get a 150-HP engine.
The delivery date is unknown.
Re: 190 MONTAUK Re-power SUZUKI 140BG
Postby jimh » Thu Mar 30, 2023 1:28 am
Thanks for this announcement. When you get the engine, have it installed, get past the break-in period, choose a propeller, and conduct on-water tests, you can start a new thread in the PERFORMANCE section.
kjang
Postby kjang » Thu Mar 30, 2023 6:37 pm
Thanks. Will do.
Postby Phil T » Thu Mar 30, 2023 7:52 pm
Make sure the dealer installs the engine with the top bolt in the third hole down from the top.
A 14x20 Suzuki stainless steel propeller would be a good one to start testing with.
kjang
Postby kjang » Fri Mar 31, 2023 9:04 pm
Thanks for the advice.
Masbama
Postby Masbama » Sat Apr 01, 2023 11:50 pm
What year is your 190 Montauk? I believe those made before 2018 had a lower hull weight.
kjang
Postby kjang » Wed Apr 05, 2023 4:25 pm
Masbama wrote:What year is your 190 Montauk? I believe those made before 2018 had a lower hull weight.
I have 2007 190 MONTAUK. I don’t know if it has a lower hull weight compared to the new 190 MONTAUK.
My SUZUKI DF140BG engine is at my dealer. To get the engine took one month. One month is not a bad wait time compared to the wait times for YAMAHA engines.
Masbama
Postby Masbama » Wed Apr 05, 2023 11:10 pm
I have a 2016 Suzuki DF140A on my 2003 190 Nantucket. It is just enough. I look forward to reading about your new boat-engine combination.
kjang
Postby kjang » Wed May 03, 2023 3:33 pm
I have received the SUZUKI DF140bg, the model with remote electronic throttle and shift controls. To get this engine took one month. To install this engine and to re-do the dash with a smart gauge took less than one week. Soon I will start the engine break-in procedure. In the future I will post performance data in the PERFORMANCE forum.
