Where can I get information on the steering cables for 1994 RAGE 14?
Thanks, Evelyn
1994 RAGE 14 Steering Cable
Re: 1994 RAGE 14 Steering Cable
What information are you looking for?
Do you have the original cables on hand?
What sort of helm is on the RAGE 14?
Assuming the steering is a manual mechanical single cable system, the cable is probably a part fitted into the helm, not something separate from the helm. Inspect the helm to locate a manufacturer name and model designator.
Once you identify the helm manufacturer and model, you can measure the cable length. The OEM manufacturer of the helm can supply a replacement cable of the desired length.
