1994 V4 140HP Evinrude Fuel Water Separator
Don SSDD
Postby Don SSDD » Sun Jul 03, 2016 1:54 pm
I changed my spin-on fuel-water separator, and now I can't get any fuel pressure with the bulb. I pre-filled the new separator with fuel being installing it.
Should the bulb pump up like normal?
I had not yet started my boat this season. Would the next logical step be to change-out the fuel line and bulb from the separator to the carburetor?
Or is there something else I could do to get fuel pressure in the bulb?
My first boat with a fuel tank and fuel separator.
Don
!991 Guardian 19
Previous 1987 Montauk 17
Nova Scotia
Acseatsri
Re: 1994 V4 140HP Evinrude Fuel Water Separator
Postby Acseatsri » Sun Jul 03, 2016 2:14 pm
Try holding the bulb straight up and down. Also, compress the bulb as much as possible, repeat quickly as soon as it returns to its normal shape. I had this same concern when I changed my filter along with a very low fuel level in the tank.
The other possibility is that the filter didn't seal perfectly. I always use a light coating of grease on the seal before I screw it on.
Don SSDD
Postby Don SSDD » Mon Jul 04, 2016 6:19 am
I used a bit of grease on the spin on on the rubber seal and tried your advice to hold the bulb up and down: still no result.
I figured all the bulb is doing is acting as a syphon to get fuel from the tank to the motor, so I removed the bulb and tried my lower unit lube fill pump. It fit nicely "in-line" inside the 3/8-inch-ID fuel line where the bulb was. It gave a lot more suction than the bulb and I got the fuel system primed easily, then I put the bulb back in. All's well now, thanks.
Don
Nova Scotia
Postby jimh » Mon Jul 04, 2016 9:45 am
Get a new BRP OEM primer bulb.
