I am very unhappy with my current trailer's bow stop assembly. The access to unhook the winch strap is impossible, and this requires a three-step process of backing the boat down with the strap attached so that access to unhook it is possible.
I am looking for suggestions and advice and if possible any pics of any existing assemblies on other trailers. My current setup makes it impossible to install a safety chain to either the winch hook or bow hook.
The pics are available here.
https://garys22revenge.shutterfly.com
Trailer Bow Stop Assembly
- IMG_0454.JPG (126.3 KiB) Viewed 4128 times
- IMG_0453.JPG (131.21 KiB) Viewed 4128 times
Re: Trailer Bow Stop Assembly
I would reverse the direction of the strap so it comes off the bottom of the spool, then raise the winch- hopefully the bow eye falls more toward the center of the bow stop in this arrangement, providing access to the towing eye.
I posted a suggestion "over there".
Compare your setup to mine:
Similar version:
It can be purchased at http://www.easternmarine.com/loadrite-boat-trailer-winch-stand-assembly-6064-02s as this
Similar version:
Leave the winch spool as it is. Raise the winch on its mounting post. This will put bow eye midway between the two bow stop rollers.
Ideally, I believe the bow eye should rest against the bottom of the bow stop. This should help keep the bow down when braking. Alternatively, a bow tiedown device can be used.
