Source for Seat Cushions, Drain Tubes
Hello everyone. I [want] to replace the seat cushions in my 1992 Montauk 17 and the main drain tube. Please tell me where i can find these to purchase. Thank you.
1995 Montauk 1995 Merc 90. Port Jefferson and Greenport NY
Re: Source for Seat Cushions, Drain Tubes
You can find recommended sources for upholstery and drain tubes in the REFERENCE section. Read the article
Original Equipment Manufacturers and
Recommended Vendors
http://continuouswave.com/whaler/reference/OEM.html
The article is listed in the TABLE OF CONTENTS of the REFERENCE section under the heading OEM PART SOURCES.
Recommended Vendors
The degree to which owners of MONTAUK 17 boats use downriggers is a good topic for THE GAM. Please use THE GAM for topics like that.
I do not believe that outriggers are the same as downriggers, but since I am not much of an angler, I might be mistaken. Either would be good topic for THE GAM.
Jim--I am sorry however i do not see anything about drain tubes.
Re: Source for Seat Cushions, Drain Tubes; Frequency of use of Downriggers with MONTAUK 17 Boats
There are dozens of threads on techniques to replace the tubes.
Here is one:
http://continuouswave.com/ubb/Forum3/HTML/000062.html
As for suppliers see FAQ #12:
http://continuouswave.com/whaler/reference/FAQ/#Q12
Then contact either
Sue Lodel, Parts Manager @ Beacon/Twin Cities Marine
http://www.beacontcm.com
- or -
McCarr Master
https://www.mcmaster.com
Here is one:
Then contact either
- or -
McCarr Master
Sorry--for advice on replacement of drains see the FAQ.
Thank you everyone !
