1989 Boston Whaler 22 Outrage Restoration
Parker Yacht
Postby Parker Yacht » Fri Apr 12, 2019 6:30 pm
Hello all. I am new to the forum. I have been a member of other sites for many years. We are a repair shop in Ft. Lauderdale the first larger Boston Whaler boat we have restored is a 1989 Boston Whaler 22 Outrage with a Yamaha F225XNCA, with Alwgrip paint, with a new fuel tank, and with new wiring.
Fig. 1. Fairing hullside.
Fig. 2. Transom shot.
Fig. 3. New fuel tank in and sealed.
Fig. 4. Hull is painted.
Fig. 5. Interior is painted.
Fig. 6. Looking down the stb cap. Cap has been finished in Awlgrip with Awlgrip Non-skid.
Fig. 7. Fuel tank is installed. Tank is coated with Hull Guard Xtra anti corrosive primer, foamed in and top of foam is sealed with 3m4200, limber holes cut in stringers to allow water to flow off tank top.
Fig. 8. Empty hull shell, painted and ready for installation of fuel tank and other components.
Fig. 9. Yamaha F250XNCA is mounted, console mounted, and boat going back together.
Fig. 10. Console was pre-wired off the boat, installed and completed.
Fig. 11. Engine mounted, stripes have been painted, Emblems installed, bottom sanded and ready for paint.
Fig. 12. Pulpit was removed; extension of bow rail over pulpit was removed; a new rail section was welded in.
Fig. 13. Console was stripped, teak was stripped and built up with spar varnish.
Fig. 14. Another view of the console from a slightly different position of the camera.
Fig. 15. We used BocaTech switches in this project. Not cheap, but look and perform well.
Fig. 16. Console installed and completed. The windscreen frame was removed,
sandblasted, prime and painted with Awlgrip.
Fig. 17. All fittings were removed, and either re-chromed or Anodized.
Fig. 18. Console completed, varnish is looking strong.
Fig. 19. Close-up of loudspeaker amplifier for music reproduction system.
Fig. 20 Some electrical wiring and other rigging inside center console.
Regards,
Ole
954 463 1515
oparker@parkeryacht.com
NLA01
Re: 1989 Boston Whaler 22 Outrage Restoration
Postby NLA01 » Wed May 01, 2019 4:36 pm
Ole:
Q1: How did you prep the hull for refinish?
Q2: What was your process for fairing the sides?
Q3: Did you use primer and paint to spray the hull or did you spray gelcoat? The non skid on the gunwale looks like paint.
Q4: Did you do glass to fill the console dash to spray?
Q5: Was it paint or gelcoat? It looks nice.
Q6: Did you spray AWLGRIP paint?
It look likes a professional job you have done. Many on this forum are DIY enthusiast and would like some input with the process of all was done in case we have similar project. It really looks top notch and very professional.
Archie
Parker Yacht
Postby Parker Yacht » Thu May 02, 2019 5:54 am
Archie—Thank you for the questions, responses below:
A1, A2: We sanded down the sides with a DA first, they applied AWLFAIR with a long straight trowel, then longboard sanded the hull sides, prepped for primer.
A3: We used AWLGRIP primers and paint. The non-skid is AWLGRIP NonSkid, done by spray method.
A4: The dash was made with a piece of FRP we cut out of a pre-made sheet we get, cut to size, routed, primed and painted.
A5: Thank you. We use the pre-made FRP sheeting to make panels, gauge filler panels, etc, we find it to be cleaner, cheaper and looks better without a ton of cost and dust.
A6: Yes, the whole boat was done with AWLGRIP, in a complete project, it ends up being a better finish that will last longer, IMO. I come from a large boat background where polyurethane paint is king.
Acassidy wrote:It look likes a professional job you have done. Many on this forum are DIY enthusiast and would like some input with the process of all was done in case we have similar project. It really looks top notch and very professional.
Thank you. Yes, we are a small shop where we restore old botes, fix new ones and are Yamaha and Mercury dealers. We have done some neat older restores, Mako, SeaCraft, Bertram, Donzi, a 15' Whaler, this was our first larger Whaler. It came out very nice.
Regards,
Ole
954 463 1515
Postby Jefecinco » Thu May 02, 2019 9:44 am
Q7: Where is the Necker Knob?
Parker Yacht
Postby Parker Yacht » Thu May 02, 2019 11:25 am
A7: The Necker knob is not there.
Regards,
Ole
954 463 1515
menauhant11
Postby menauhant11 » Fri May 03, 2019 11:21 pm
Thank you for sharing the progress on your restoration. I'm the owner of a 1991 22' Outrage Whaler Drive with some considerable restoration work completed but original gelcoat and fuel tank. However I have always contemplated what it would look like to restore the entire boat using AWLGRIP.
Q8: Are those AIRBPAX-brand switches? [See the caption at Fig. 15 to find the brand--jimh]
Q9: How did you re-secure the bow rail fittings?
Q10: Did you install a backing plate [for the bow rail fitting]?
Q11: [Are the bow rail and its fittings] OEM? [See the caption at Fig. 12--jimh]
Maverick
Postby Maverick » Sat May 04, 2019 6:25 am
Parker Yacht, thank you as well for sharing the restoration progress. Looking great.
I've worked with gelcoat a good bit, and have read where some folks are using AWLGRIP instead of gelcoat.
Parker Yacht wrote:Yes, the whole boat was done with AWLGRIP. In a complete project, AWLGRIP ends up being a better finish that will last longer. I come from a large boat background where polyurethane paint is king.
[Five] questions:
Q12: Do you mix and spray AWLGRIP like an automotive finish base coat and clear coat?
Q13: Is a special gun required?
Spraying or rolling gelcoat is quite a mess and a chore, hence my interest in AWLGRIP application, if simpler and easier as with a base and clear coat application.
Q14: How does AWLGRIP hold up to weather topside?
Q15: How does AWLGRIP hold up underwater?
Q16: [Does AWLGRIP have] as good or better [durability] than gelcoat?
Don McIntyre - MI
Postby Don McIntyre - MI » Sat May 04, 2019 7:29 pm
A concern with using a polyurethane paint like AWLGRIP below the water line is that many of us will beach our boats on a sandy surface. I've beached my renovated 1973 21' Outrage maybe a dozen times--but only for brief periods because I know that the paint applied on the bottom is thinner then gel coat resin.
For spot refinishing, the newer poly[urethane paint]s are great once the paint color is matched.
You could probably use poly[urethane paint] [on the hull sides down to the waterline, to where the vertical hull sides meet the edge of the bottom.
One weathering [problem] absent with a poly[urethane paint] is chalking or fading as occurs with gelcoat. However, with gel coat on the topside, you can get away with some pretty aggressive grit when polishing. Even to the point of wet sanding in the 1000 to 2000 grit range prior to wheeling with multiple compounds, thence waxing.
Regards - Don
Postby jimh » Sun May 05, 2019 9:24 am
Q17: What is the purpose of the blue mats seen in many of your illustrations?
Parker Yacht
Postby Parker Yacht » Mon May 06, 2019 6:20 am
A11: The bow railing was OEM, and it did have a pulpit section, which we removed.
Regards,
Ole
954 463 1515
Parker Yacht
Postby Parker Yacht » Mon May 06, 2019 6:28 am
A15: AWLGRIP doesn't work underwater. It will get blisters after about ten days in the water
A16: AWLGRIP has as good or better durability than gelcoat, but there are people who will disagree.
Regards,
Ole
954 463 1515
Parker Yacht
Postby Parker Yacht » Mon May 06, 2019 6:29 am
A17: The blue mats seen in many illustrations are Eagle Cover Guard material to give protection for the deck and other areas.
Regards,
Ole
954 463 1515
Postby jimh » Mon May 06, 2019 11:47 am
Nota Bene: many new illustrations are being added to the original article in the thread. Check that article for new content.
