305 Conquest Separating Helm Panel from Hull
sac56fire
Postby sac56fire » Thu May 09, 2019 9:14 am
I am re-powering my 2005 305 Conquest. I want to remove the large one-piece panel that covers from the cabin door to the engine throttles. It has a caulk bead around the entire panel. I assume it has putty underneath to keep it from rattling.
Has anyone removed this panel?
{Give me] pointers.
Thanks.
Steve
Boston Whaler console.jpg (88.52 KiB) Viewed 3947 times
Re: 305 Conquest Separating Helm Panel from Hull
Postby Phil T » Thu May 09, 2019 9:27 am
This is the factory diagram for the console.
http://bostonwhaler.com.s3.amazonaws.com/resources/305-Conquest-Console-Assembly-with-Parts-List-2005.pdf
Here is the diagram for Final Assembly - Exterior. See Sheet 3.
http://bostonwhaler.com.s3.amazonaws.com/resources/305-Conquest-Final-Assembly-Exterior-with-Parts-List-2005.pdf
This and 34 other drawings and parts diagrams are available for your year/model at https://www.bostonwhaler.com/boat-ownership/resources/ Just enter YEAR, MODEL FAMILY, MODEL and ALL TYPES.
Hope this helps.
Postby jimh » Thu May 09, 2019 12:13 pm
I would expect that a major laminated part such as the helm panel shown above would be installed and bonded to the rest of the hull using strong adhesives. I doubt the panel will be easily removed due to the strength of the adhesives.
I recommend you contact Boston Whaler customer service to get their advice. I would be surprised if any 305 CONQUEST owners reading this thread have attempted to or succeeded in removing that panel.
sac56fire
Postby sac56fire » Thu May 09, 2019 6:41 pm
Thanks for the replies. [The helm panel assembly of the 305 CONQUEST] is bonded to the hull with adhesives. I will continue to try to separate [the helm panel] from the hull. I have a week before [the 305 CONQUEST] goes to the shop for re-power.
I would like to have full access behind [the helm panel].
Steve
