Replacing Brass Through-hull Fittings
Postby jimh » Wed Nov 18, 2020 10:19 am
A Boston Whaler boat owner demonstrates the method for replacement of a brass through-hull fitting that permits use of a flanging tool to flare the brass in a self-made youTube presentation at
https://youtu.be/YELHcWOQNm8?t=116
Re: Replacing Brass Through-hull Fittings
Postby Phil T » Wed Nov 18, 2020 4:32 pm
Add one more step -
Prior to inserting cut and prepped drain tube, you should coat the sides of the drain tube hole with marine sealant and let cure.
Marine sealant should be used rather than an adhesive under the O ring.
Postby jimh » Sun Nov 22, 2020 11:10 am
Several posts on a new topic have been removed from this thread discussing a youTube presentation that demonstrates use of brass tubing and a flaring tool. Those posts covered two new entirely different topics and are now in their own two separate threads.
