I would like to install an automatic sump pump in a 1976 MONTAUK. The curved bottom of [the pump I have has a] drain tube [that] makes [this pump] hard to mount. I could not tell from photos online if all [electric sump pump available have drain tubes that] are curved like [the pump I bought].
Q1: on a 1976 MONTAUK what is the best location for a sump pump?
Q2: if the best location is in the [aft cockpit centerline sump], how should the pump be mounted?
Photos: https://imgur.com/a/bCTgDpF
The the outboard rigging is chafing on the lip of the [engine splasw] well [forward] of the engine. The [engine]rigging does not seem long enough to tie to the metal thru hull fitting.
Q3: what can be done to solve the chafing?
1976 Montauk 17 Sump Pump Location; Chaffing Engine Cables
Re: 1976 Montauk 17 Sump Pump Location; Chafing Engine Cables
Most small centrifugal electric sump pumps have a flat mounting base. They also have an associated mounting plate that will retain the pump in a fixed position. The pump output hose barb is located slightly above the base.
The remedy to your mounting problem is to change to a different pump with the pump base flat and the output hose barb just above the base. Get a pump with internal water sensing; this will eliminate the float switch assembly. There is insufficient room in the aft centerline cockpit sump for both a pump and a float switch.
The aft centerline cockpit sump is the best location on the 16/17-foot hull for locating a sump pump. The exhaust hose of the sump pump should be led aft and over the transom. Do not have the pump exhaust drain into the engine splash well.
Re: “metal thru hull fitting”
Your descrption of the portion of the boat “metal thru hull fitting” is unclear. Perhaps you are trying to refer to a transom-mounted lifting/towing eye. Please explain more clearly.JackC wrote:The [engine] rigging does not seem long enough to tie to the metal thru hull fitting.
Generally the compound adjective “through-hull” refers to drains, not to hardware like a towing eye. The towing eye is through-bolted onto the transom. I can’t deduce how the engine rigging would be tied to a through-hull drain.
