Q1: is a wood locating diagram available for a 1993 21 WALKAROUND?
I contacted Boston Whaler to see if they could provide confirmation that my 1993 21 WALKAROUND has embedded reinforcement in the bow, but they were unable to find the wood locating diagram.
BACKSTORY
I recently purchased a xi5 36-Volt 72-inch-shaft 105-lbs-thrust electric trolling motor to mount on my 1993 21 Walkaround. I’m unable to get past the anchor locker to mount it with through-bolts up towards the rub rail on the bow.
I ordered a bracket from ShuttleSlide that should allow me to through-bolt the trolling motor bracket above the anchor locker, then slide the trolling motor up into the appropriate location.
That said, I’ve been reading the forums about whaleboard or phenolic material reinforcement that can be drilled and tapped for machine screw fasteners to mount a trolling motor If possible, I’d rather install the trolling motor this way to declutter the bow, as the shuttle slide bracket and adapter-extension will be relatively large compared to only using the Motorguide quick release bracket.
1993 21 Walkaround Wood Locating Diagram
Re: 1993 21 Walkaround Wood Locating Diagram
I am sadden to hear that Boston Whaler customer service could not provide a wood locating diagram for your 1993 21 WALKAROUND boat. I hope they didn’t purge their records archive of old drawings like that one.
Boston Whaler Customer Support has been centralized and scaled way way back. They are referring owners of models no longer in production to the owner sites on the internet.
