Source for Trailer Bunk Brackets
SpongeBob
Postby SpongeBob » Sat Aug 19, 2023 9:32 pm
I’m redoing a trailer for a 13-footer.
I would like to use [mounting] bunk brackets that are flat plates of galvanized steel[and have the dimensions of 0.25-inch x 2.00-inch and an unspecified third dimension], and have holes drilled every 2 1/ inches [perhaps means every 2.5-inches] or so over their full [unspecified] length.
The trailer bunk brackets I want are NOT like the traditional U channel brackets usually seen.
What is a source for trailer bunk brackets {as described above]?
Jeff
Re: Source for Trailer Bunk Brackets
Postby jimh » Sun Aug 20, 2023 5:34 am
Do you have a photograph of the trailer bunk bracket you prefer?
Have you checked at Eastern Marine's TRAILER PARTS SUPERSTORE?
https://www.easternmarine.com/trailer-tongues-crossbars-rails
