On a c.1998 to 2003 295 CONQUEST or a CONQUEST 28, how can the Port fuel sending unit be replaced?
With the access points that Boston Whaler has provided, I do not see a way to replace the Port fuel sending unit on a c.1998 to 2003 295 CONQUEST or a CONQUEST 28
--Pete
1998-2003 Conquest 28/295 Port Fuel Sending Unit
Re: 1998-2003 Conquest 28/295 Port Fuel Sending Unit
I am not sure what component you are asking about as a "fuel sending unit." Normally a "fuel sending unit" might be something like an in-line fuel flow instrument.
Q2: Are you asking about a fuel tank level sender that is installed on a fuel tank on the port side of the hull?
Pete -
Do you have all the parts information and diagrams?
Enter year, model family and model here:
https://www.bostonwhaler.com/resources-and-maintenance.html
Here is a diagram.
Here is a diagram.
- 295-Conquest-Hull-Assembly-Sheet-1-of-2-2003.jpg (113.21 KiB) Viewed 358 times
