1972 OUTRAGE 19 Re-power: Fuel Used by V6 Engine compared to V4
stubaird
Postby stubaird » Mon Jan 21, 2019 11:38 am
I own a 1972 19 Outrage with a Nissan 90-HP two-stroke-power-cycle outboard engine. The 19 OUTRAGE runs well, but it is underpowered. I'd like to upgrade to have more power, but I don't want to put too much weight on the transom.
This 1972 19 OUTRAGE was originally a sterndrive which was converted to outboard power by filling in and fixing the transom, and adding a set-back bracket and jack plate. I may buy a c.1995 OMC two-stroke-power-cycle outboard with carburetors because they are available, are generally lighter than modern outboards, and I am familiar with them and can do most of the maintenance myself. The weight difference between the OMC V4 engines and V6 engines of that era doesn't seem too much.
For the same boat, same load, running at the same speed, would a V6 use significantly more fuel than a V4?
Stu
Re: Fuel Used by V6 Engine compared to V4
Postby jimh » Mon Jan 21, 2019 12:19 pm
The ability of an engine to convert fuel to horsepower is called the Brake Specific Fuel Consumption or BSFC. For most gasoline internal combustion engines, the BSFC is not a constant figure. BSFC varies as engine RPM and load vary. It is hard to know exactly where the BSFC will be the least, that is, at what combination of engine RPM and load the engine will be most efficient at converting fuel to power.
To propel a particular boat to a particular speed will require the same horsepower, no matter if the engine providing the power has four-cylinder or six-cylinders, both in V-block configuration.
Among OMC engines, the V4 and V6 engines may use identical cylinder dimensions, which suggests the total displacement of the V6 engine would then be in a ratio of 6/4 compared to the V4, or, in other words, the V6 will have 1.5-times the displacement. Again, this is true only if the individual cylinder dimensions are the same.
With that background in mind, we approach your question:
The answer is difficult to give with precision. The assumption that the same horsepower is needed in both instances is a reasonable assumption, assuming that the underwater gear in both instances is the same, that is, the gear case, the gear ratio, and propeller are the same. However, that may not be a good assumption. It is likely that the gear case may be of similar size, but the gear ratio and the propeller pitch may be different.
There seems to be a popular notion that an engine of high rated horsepower will be more efficient running at a less-than-full throttle RPM because it will be "loafing" to make its power compared to another engine with lower rated horsepower that must be "working" to produce the same power output. However, this is not always completely true. It depends on the BSFC of each engine. A larger engine "loafing" with a smaller load (in proportion to its total horsepower) may actually be operating at a point on its BSFC curve that is less efficient than a smaller engine "working" with a larger load (in proportion to its total horsepower) that is operating at a more efficient point on its (different) BSFC curve.
About the only sure thing that can be said regarding fuel consumption of the two engines: if you run the more powerful engine at a higher power setting than you run the less powerful engine, the bigger engine is sure to burn more fuel.
Another anecdotal observation: many older two-stroke-power-cycle outboard engines run most efficiently, that is they have the best (lowest) BSFC, when they are operating under load in a range of RPM that is about 0.8 of their rated maximum engine speed. For example, if the engine is rated to run at 5,500-RPM, the best BSFC might be around 4,000 to 4,400-RPM. But, again, this is really an anecdotal observation.
In either case, I would not expect the fuel consumption rates to be hugely different. And unless you use the boat hundreds of hours every year, the effect of a small difference in fuel consumption will only cause a small change in your fuel costs.
Postby jimh » Mon Jan 21, 2019 12:33 pm
A chart found on
https://www.dynomitedynamometer.com/dyn ... g_bsfc.htm
shows measured BSFC for several engine types. In the categories listed, the appropriate category for an c.1995 OMC outboard engine would be "2-stroke (low compression, carburetor)." The chart lists these measured BSFC values for such an engine:
    BSFC for a 2-stroke (low compression, carburetor)
    At 1,000-RPM = 0.80
    At peak torque = 0.55
    At peak horsepower = 0.60
This suggests that you want the engine operating speed to be around the peak torque output point for best BSFC. For a two-cycle carburetor outboard, the torque output usually peaks below the maximum rated engine speed. There is very little published data from outboard engine manufacturers that gives the engine torque curve. Again, from anecdotal observations, the peak torque in a two-stroke engine often occurs in the engine speed range that is about 0.8 of the maximum rated speed.
The above cited data also shows that at low speeds, the BSFC of a carburator low-compression two-stroke-power-cycle engine is very high. This also correlates with my anecdotal observations. The fuel economy at idle speeds was often worse than at full-throttle speeds.
Re: 1972 OUTRAGE 19 Re-power: Fuel Used by V6 Engine compared to V4
Postby jimh » Mon Jan 21, 2019 12:47 pm
If you are not familiar with BSFC numbers, the units (used above) are in lbs/HP-hour. For example, if an engine makes 50-HP, runs for 1-hour, and has a BSFC of 0.55, then it will consume [UPDATE: I fixed a big math error that was in the original example I gave--jimh]
    50-HP x 1-Hour x 0.55-lbs/HP-hour = 27.5-lbs fuel
If the fuel is gasoline with a density of about 6.25-lbs-per-gallon, then the volume of fuel consumed will be
    27.5-lbs-gasoline x 1-gallon-gasoline/6.25-lbs = 4.4-gallon gasoline
Regarding the density of gasoline, the "Engineering Toolbox" site lists the density of gasoline as 45 to 49-lbs per cubic foot. One US-gallon is 0.13368-cubic feet. Therefore the density of gasoline as 45 to 49-lbs per cubic foot is the same as 6 to 6.55-lbs/gallon. I use an average value of 6.25-lbs.
stubaird
Postby stubaird » Thu Jan 24, 2019 8:26 am
Thanks Jim, that is very helpful.
Stu
