2005 19 Nantucket Four-blade Propeller
johnbert35
Postby johnbert35 » Thu Jun 20, 2019 8:47 am
Has a four-blade propeller ever been used on a 2005 190 NANTUCKET?
[My 2005 190 NANTUCKET has] a three-blade 15.5 x 17-pitch stainless propeller, and I would like to change to a four-blade propeller.
Masbama
Re: Prop Selection 2005 19' Nantucket 135 hp Mercury
Postby Masbama » Thu Jun 20, 2019 11:01 pm
I am going to try a four-blade propeller on my 2003 190 Nantucket with a Suzuki DF140.
Postby Phil T » Fri Jun 21, 2019 10:46 am
John -
The size will depend on what brand/model you are moving to since prop sizing is not universal.
While it is typical to move down in pitch, I would not want to hazard a guess. I would seek out a prop shop that is familar with Whalers.
One place that is a go-to for me is Ken Reeves @ PropGods. He is very knowledgeable about whalers and props. Many members here have used him.
https://propgods.com
Re: 2005 19 Nantucket Four-blade Propeller
Postby jimh » Fri Jun 21, 2019 11:59 am
johnbert35 wrote:...I would like to go to a four-blade propeller.
I think you should get a four-blade propeller if you want one, even if no one else does.
You should abandon the OEM propeller that Boston Whaler chose for your boat and get a different one with four blades, if that is what you want.
johnbert35
Postby johnbert35 » Sat Jun 22, 2019 7:28 am
Masbama wrote:I am going to try a four-blade propeller on my 2003 190 Nantucket with a Suzuki DF140.
Please let me know how you make out with the four-blade and its size.
Postby jimh » Sun Jun 23, 2019 9:14 am
Here are results of the factory testing and propeller selection:
http://continuouswave.com/whaler/refere ... ucket.html
The factory selected the MIRAGEplus 17-pitch. The performance looks very good. To obtain improvement will be difficult. The three-blade propeller is generally the best all-round propeller and is the choice in almost every Boston Whaler OEM rigging.
flymo
Postby flymo » Sun Jun 23, 2019 10:07 am
John:
Q: what engine does your boat have?
Q: what aspect of performance do you want to improve?
