19' Outrage II Re-power Yamaha XB115
hesse3
Postby hesse3 » Wed Jul 08, 2020 6:31 pm
I just re-powered my 1995 19 Outrage II with a Yamaha XB 115 four-stroke-power-cycle engine manufactured in 2019.
The 19 OUTRAGE II boat reaches plane in four seconds and has a top speed of 40-MPH at engine speed of 5900-RPM; data taken with 70 gallons of fuel aboard. I am very happy.
Re: 19' Outrage II Re-power
Postby jimh » Fri Jul 10, 2020 11:25 am
The top boat speed of 40-MPH seems very good for a 115-HP rated engine. I have seen 19 OUTRAGE II boats with older Yamaha V6 150-HP engines; I don’t think they were all that much faster.
What does the “XB” model designation mean?
What is the engine weight?
Re: 19' Outrage II Re-power Yamaha XB115
Postby Phil T » Fri Jul 10, 2020 12:41 pm
Please also post the propeller make/model and size and the mounting height of the engine.
Postby biggiefl » Fri Jul 10, 2020 1:04 pm
My 1986 18' outrage with a F115 with 13x17 painted Yamaha SS prop will hit 40-41 around 5900-6k with bimini up and a lot of fuel mounted all the way up. I do have (very old & faded) bottom paint and 2 batteries in the stern. Pretty good for your boat which weighs more.
Postby Phil T » Fri Jul 10, 2020 1:20 pm
The recently redesigned F115 reduced its weight from 402 lbs dry weight to 386 lbs. These are long shaft specs.
Postby Phil T » Fri Jul 10, 2020 1:22 pm
In posting the weights I note the WOT range on the recently redesigned F115 is 5300-6300.
I think there is a little more room for improvement for Hesse if he is interested.
Postby biggiefl » Mon Jul 13, 2020 12:07 pm
With 70 gallons of fuel and hitting 40-MPH at 5900-RPM, I would leave it alone.
