Lowrance Elite 4: Glare on Screen
Tom C
Postby Tom C » Fri Oct 30, 2015 4:52 pm
I have mounted a Lowrance Elite 4 DSI on the console of my 1988 SUPER SPORT 15. If the sun is bright I cannot see the readout unless I shade the screen with something, usually my cap. This takes my hands off the wheel. Have others found a solution for this problem? I contacted Navico and they do not offer anything to attach to the unit that would help. Suggestions?
Re: Lowrance Elite 4: Glare on Screen
Postby Jefecinco » Fri Oct 30, 2015 7:33 pm
If you can't find an adjustment to the screen angle that allows viewing you should be able to fabricate a hood from some thin pliable material and attach it to the sounder to reduce the glare. It could be mounted using heavy duty velcro or an elastic band. On youtube.com there are examples.
Postby jimh » Fri Oct 30, 2015 9:35 pm
The color display on an Elite 4 is not going to have enough contrast-ratio or brightness to be seen in direct sunlight. You'll have to create some shade for it. Screen glare is usually not too bad, unless the anti-glare coating has been rubbed off.
Hoosier
Postby Hoosier » Sun Nov 01, 2015 9:17 am
Just a wild idea but would a computer monitor privacy screen help? They change the visibility angle to just about straight on and would reduce glare coming in from the sides.
1978 Outrage V20 with 2004 Suzuki DF-115. 1992 23 Walkaround with two 2010 Yamaha F-150s.
Postby jimh » Sun Nov 01, 2015 10:16 am
Go to an art supply store. Buy some black matboard used for picture or poster mattes. With black duct tape, make a screen shade.
Hoosier
Postby Hoosier » Sun Nov 01, 2015 10:17 am
Tom C
Postby Tom C » Tue Nov 03, 2015 8:34 am
Thanks to all for suggestions,etc. I have taken the brim off an old visor and attached it with velcro. It works great in the garage but the test will be when wind and sun are added. May have to wait awhile as we are having a wet spell here in SW VA.
Peter
Postby Peter » Wed Nov 04, 2015 9:27 am
Interesting. I have an Elite 5 HDI on one of my boats and I also have a hard time seeing it in sunlight. Have not had this problem with another brand used in the same circumstances.
