Remote Battery Switch 36-Volt Rating
Boat_Fun_123
Postby Boat_Fun_123 » Thu Sep 14, 2017 11:38 am
I am interested in finding A Remote Battery Switche, similar the Blue Sea 7000, that can switch simple on-off for 36-Volts and under 100 Amperes. Blue Sea Systems have the 12 and 24 Volt versions. I like Blue Sea's design because they draw no current while in the bi-stable state of on or off, but only draw current when changing states. That is why I don't want a simple relay or solenoid.
Scott
Re: Battery Remote Switch
Postby jimh » Thu Sep 14, 2017 1:07 pm
Check BEP line. Their battery switches are rated for 48-Volt. Maybe they have a remote switch with similar rating.
I am not too keen on a LATCH-ON switch--how do you shut off the circuit if there is a problem with the switch?
Boat_Fun_123
Re: Remote Battery Switch 36-Volt Rating
Postby Boat_Fun_123 » Thu Sep 14, 2017 5:15 pm
Jim,
It's understandable you'd ask that question. These particular 12 and 24 volt Remote Battery Switches also have a mechanical on/off at the switch to manual connect/disconnect.
Scott
InVision
Postby InVision » Fri Sep 15, 2017 8:54 am
I am not totally sure I understand. But for 36V trolling motors which have a 60 AMP capacity we use a normal 12v switch and a 60 amp relay near TM. That way we don't have to run big expensive wire to the console.
I apologize if I am not understanding what your looking for.
M
Boat Photos
Postby Jefecinco » Fri Sep 15, 2017 9:12 am
BoatFun said he didn't want to use a relay.
InVision
Postby InVision » Fri Sep 15, 2017 9:25 am
Yes sir. I understand
Boat Photos
Postby jimh » Sun Sep 17, 2017 8:59 pm
Somewhat tangential to the topic of where to get a remote battery switch that can handle 36-Volts at 100-Amperes and has no current demand for operating its switch action except when changing states: why is such a remote controlled switch needed on a small boat?
I can understand how on a large boat one might have a helm station that was a great distance from the battery bank providing the 36-Volts at 100-Amperes, but on a smaller boat, I cannot imagine you could get very far away from those batteries and a manual switch controlling them.
Also: how long will the circuit providing the 36-Volts and 100-Amperes be energized? If the batteries are supplying 100-Amperes at 36-Volts, the current needed to hold in the coil of a relay would only be a miniscule fraction of the total load, probably less than 1-Ampere at 12-Volts, or about 0.3-percent of the total load on the battery bank. What application would be so critical that adding 0.3-percent to the total load would make a significant difference in performance?
