SPORT 15 with F70
El Rollo
SPORT 15 with F70
Postby El Rollo » Wed Apr 03, 2019 12:32 am
I have a 1988 Boston Whaler 15 with a Yamaha F70 and a five-inch manual jack plate.
I have added additional weight to the boat: a trolling motor and three small batteries.
When I finished the project of restoring the boat, I tested several propellers. Ultimately I found that a four blade worked best overall for this' particular set-up. With the odd weigh-distribution of the boat, the four-blade helped keep the bow down, and reduced bow oscillation. I saw much better [acceleration from a standing start] as well as a reduced and more comfortable cruising speeds. Docking and off-plane maneuverability was also greatly improved with the four-blade. One unexpected characteristic of the four-blade was the ability to raise the motor higher than with the three-blade. I am very happy with the current set-up.
TFrere
SPORT 15 with F70
Postby TFrere » Wed Apr 03, 2019 9:31 am
EL ROLLO: what propeller did you choose for your SPORT 15? I have the same boat (1985 15’ Sport) and engine (Yamaha F70) but without the jack plate, the trolling motor, and the extra batteries. I have been considering a four-blade. Most of my running is in the 4000 to 4500-RPM range and top-end speed is not important.
El Rollo
Re: SPORT 15 with F70
Postby El Rollo » Thu Apr 04, 2019 11:58 am
TFrere: the propeller I have is a Turbo Flats X 13-1/4" x 14" and is now named the Turbo FX4. Yamaha bought Turbo propellers and re-branded some of the names, but kept the same propeller design for this model.
Keep in mind that I selected this propeller as a bandaid to help compensate for the additional weight, and poor weight distribution in my 15.
The jack plate allowed me to raise up the engine higher than I could have if it were mounted on the transom.
I have a feeling you wouldn't be satisfied with my particular prop in your case.
Someone on this board did some good research and was happy with a Powertech SCD propeller. I believe the SCD stands for Semi-Cleaver Design. There are three- and four-blade versions of this propeller available.
I seem to remember someone on this forum said the Powertech propeller worked very well with the F70 on his 15 and he was extremely happy. I plan on trying the Powertech some day, just for kicks.
Postby Phil T » Thu Apr 04, 2019 2:13 pm
TFRERE: I think El Rollo is referring to a 13 x 16 PowerTech SCD; that is the propeller I have on my propeller recommendation sheet from members testing.
If you want to know the four-bladed size conversion, I would consult Ken at http://www.PropGods.com. He knows Powertech and Boston Whalers. He has help a lot of owners here and he can get you the right propeller on the first go.
Sound right, El Rollo?
TFrere
Re: Thanks
Postby TFrere » Thu Apr 04, 2019 3:27 pm
Thanks Phil
El Rollo
Postby El Rollo » Sat Apr 06, 2019 5:58 pm
Phil T wrote:TFRERE: I think El Rollo is referring to a 13 x 16 PowerTech SCD
PHIL--Yes and thank you. [A 13 x 16 PowerTech SCD propeller] is indeed what I was referring to. I"m very curious as to the characteristics of the Powertech SCD four-blade propeller compared my current propeller.
In calm water the tips of my current propeller are actually breaking the surface of the water with the motor trimmed out about halfway. In tight turns, the propeller still does not [ventilate], which is great. Thank you for your great feedback.
TFrere
Postby TFrere » Sat Apr 06, 2019 6:19 pm
Phil: I contacted Ken with Propgods and he recommended the PowerTech SCD4 in 16-pitch. Thank you [and thank you EL ROLLO]
El Rollo
Postby El Rollo » Sun Apr 14, 2019 7:01 pm
TFrere wrote:Phil: I contacted Ken with Propgods and he recommended the PowerTech SCD4 in 16-pitch. Thank you [and thank you EL ROLLO]
If you can, please report back with your thoughts and results of the new Powertech prop.
I am really curious how it works out for you.
TFrere
Postby TFrere » Sun Jun 09, 2019 10:32 pm
El Rollo: I ended up purchasing a SCD3 in 17-pitch, but haven’t been able to test it yet. My wife and I took a ride but she gets nervous when the boat gets over about 35-MPH
My engine is mounted at two-holes-up. I think I need to raise the engine one more hole.
I’ll post again after further testing.
Simon
Postby Simon » Sun Jul 07, 2019 5:44 pm
I plan to soon replace my aluminum propeller, and I have been researching the POWERTECH SCD3 propeller.
What are [the results] with the 16-pitch?
With the 17-pitch?
I'm still deciding which pitch to purchase. I have an F70 on a 15 CENTER CONSOLE. Thanks.
1987 15' Sport CC
TFrere
Postby TFrere » Sun Jul 07, 2019 10:55 pm
[My Yamaha F70 engine accelerates to] 6,000 RPM with the SCD3 13.25 x 17. My boat is a 1985 15 Sport with a 2014 Yamaha F70. Boat speed is 42-MPH with a light load of two adults, 9/gallons of fuel, and some light gear. My motor is mounted two-holes-up.
Simon
Postby Simon » Sun Jul 07, 2019 11:51 pm
Thanks TFrere.
My engine is mounted two-holes-up as well. I might give the 16-pitch a try to see if the engine hits the 6200-RPM range with two adults and light gear.
1987 15' Sport CC
flymo
Postby flymo » Mon Jul 08, 2019 8:25 am
I have tried both the 16-pitch and 17-pitch. I ran the 16-pitch for a couple of years and loved it: great midrange acceleration and holds plane very well. However, when running light and fast I could hit the rev limiter at 6450-RPM and 43-MPH. Even before that the engine felt like it was running out of breath a bit. I switched to the 17-pitch, and I didn't notice any negatives. I have not really been able to do much fast running yet to check out the top end.
To me, the choice between 16- and 17-pitch would depend on: how heavily the boat is typically loaded; whether the engine runs at WOT very often; and if you want that last increment of speed. In retrospect, I probably should have saved my money and stuck with the 16, as I really don't make use of the top end all that much, and I'm a good load just by myself.
Simon, if I am remembering right your boat was always pretty fast. If you want to try the 16, and end up feeling you should have gotten the 17 I'll be happy to swap you.
Simon
Postby Simon » Thu Jul 18, 2019 12:03 pm
flymo wrote:I have tried both the 16-pitch and 17-pitch. I ran the 16-pitch for a couple of years and loved it: great midrange acceleration and holds plane very well. However, when running light and fast I could hit the rev limiter at 6450-RPM and 43-MPH. Even before that the engine felt like it was running out of breath a bit. I switched to the 17-pitch, and I didn't notice any negatives. I have not really been able to do much fast running yet to check out the top end.
Hi there,
I plan to order the SCD3 in 16 pitch very soon. I'll contact Ken at prop gods. If it doesnt work out and the 17 pitch may be better for my boat I'll be happy to trade with you.
Simon
1987 15' Sport CC
Simon
Postby Simon » Wed Aug 21, 2019 12:05 pm
I tested the Powertech SCD3 13x16. Compared to my Yamaha aluminum 17" K series prop, it performed much better all around. The acceleration is quicker, I can feel way better acceleration at all engine speeds, and the engine was able to accelerate to over 6,000-RPM with almost zero trim.
The boat was loaded with two people (290-lbs), thre batteries, a bow-mount trolling motor, a full cooler on bow, 18-gallons of fuel, and fishing gear. Tested at a lake on a very windy day so the chop made it hard to do WOT speeds. It was very noticeable that the boat rides much better with less bow oscillation, and the propeller being tested kept the bow much lower and stable when under way.
When I trimmed the motor up about 1/4 of the way, the boat accelerated much faster than the aluminum prop. With the powertech SCD3 13x16 I was able to reach 40 mph with almost no trim at little over 6000 rpms. I think if conditions were much calmer I can reach 6300 rpms and about 42 mph. Certainly happy with the performance so far, however I need to do more testing. Will report back soon.
Simon
1987 15' Sport CC
Postby biggiefl » Wed Aug 21, 2019 2:51 pm
We all know four-stroke-power-cycle outboard engines like to be propped to reach high in the band of their redline. I like to prop my boats so that with just me, 1/4 tank or so fuel and ideal conditions and trimmed to the max, I am just at or real close to my redline. If I am 100rpm higher I will usually take it to a prop shop and have some cup added to get it back to redline. This is probably why I get the results I do with performance. Now how often do I drive loaded like that? Enough but we all bring people in the boat and fill the tank to full which still leaves me in the "range" and usually not much lower than redline. ie: redline is 6k and I am at 6k, with 4 people, coolers, bimini top up and fuel I am still touching 5700 I am happy with that setup. I never want to prop with it able to run higher than redline as it really kills your cruise and possibly MPG and no engine should be run higher than is posted.
My point is if you propped your hull to hit redline with the load you described, I think you need more pitch.
Simon
Postby Simon » Wed Aug 21, 2019 5:34 pm
biggiefl wrote:...if you propped your hull to hit redline with the load you described, I think you need more pitch.
I totally understand what you mean and I've thought about it for a few months while reading almost everything online. It all came down to how I use my boat. It's always loaded with gear and I've never fished alone or driven the boat alone, except for when launching and retrieving at ramp. My redline is 6300 rpms and right now I'm right around 6000 rpms, so with trim it will be close to 6300 rpms and maybe I might still get 43 mph. That's the fastest speed I've ran on the old 17" aluminum. After some more testing, if I keep hitting redline with 2 people then I'll move up in pitch with a trade with Tim.
Simon
1987 15' Sport CC
El Rollo
Postby El Rollo » Thu Aug 22, 2019 10:04 am
Those are impressive numbers, especially with all the gear you have on board.
Everything I hear about the Powertech SCD Props on the 15 Whaler / F70 combo has been good.
I have the same hull / motor as you but running a Bobs 5" manual jackplate and a 4 blade prop.
The set up allows me to raise the motor quite high for running in shallow water.
Last Saturday I ran my 15 on the Colorado River from Blythe California down to Lake Martinez and back, which was 130 mile round trip.
There was a fuel stop half way at a place called Walters Camp.
The water is very shallow with sandbars the entire way, having the jackplate raised up really helped out.
Interestingly I have almost raised the motor to it's maximum height. If I trim out the motor too far I'm just starting to see the water pressure drop.
The prop however is still gripping good when raised up and trimmed out.
Postby biggiefl » Thu Aug 22, 2019 10:57 am
Good that you have a water pressure gauge with a jackplate. I had a 15 with a 70 OMC and my best was 48.6 on GPS. I had a 15 with a 60 OMC 2cyl w/o PTnT that would do 41+. I had a 15 w/o PTnT with a 48spl that would do 36+. I am very disappointed with the top speed of the 4 strokes I am seeing so far on 15's. I had a 70 Suzuki 4 stroke on a 5" jackplate that would almost hit 40.....on a NewTauk 17'. I am half tempted to buy my 5th 15' to experiment with.
El Rollo
Postby El Rollo » Thu Aug 22, 2019 12:07 pm
You've have a lot more experience than me with the 15 hulls. That OMC 70 sounds like a BEAST.
I'm really happy with my set up for what I do.
I would like to play around a little more with a couple props and jackplate heights. But as i'm sure you know, they're not cheap.
I would like to try the Powertech SCD 4-blade to see how it compares to my FX 4-blade.
Fully-trimmed out and lightly loaded I have to watch out or I'll hit 6400. I think I'll have some cup put into the FX 4 and get it tuned while it's in there.
The classic 15 hull is such a fun little boat to run, I get comments on it everywhere i go.
Postby biggiefl » Thu Aug 22, 2019 12:18 pm
It was actually the 3cyl 60 with rejetted carbs so not quite sure what the HP was but at least 70. I had another with a 70 Evinrude and she did around 44-45 but was mounted in the blind holes. I bought it as a flip so did not bother. 3 blades are faster than 4s....usually.
El Rollo
Postby El Rollo » Thu Aug 22, 2019 12:37 pm
The way I set mine up for fishing has some weird weigh distribution going on. When I initially set it up I had a Yamaha
3-blade Performance series 16" pitch which was faster, but the bow would porpoise too much when I was trimmed out.
I had some credit at a shop, so I tried the 4-blade and it really helped the porpoising a ton. I know it's a band aid of sorts but I've got the boat set up the way I like it. I have not got a gps speed on it yet, as I'll probably be disappointed. I'm guessing high 30's. Now you've got me interested to go
down and keep testing.
flymo
Postby flymo » Tue Sep 10, 2019 7:38 pm
Simon, just getting caught up with this thread - glad you're having fun with the SCD-3! It really wakes the motor up, doesn't it? As you mention, acceleration is much better at every speed, but even more importantly you can hold plane at much lower speeds. I was out with my wife today in variable conditions and the ability to quickly throttle down and back up was very helpful - she does not like getting bounced around!
It's interesting - the SCD-3 is an update on the much older semi-cleaver design, but the lower blade area and low rake really works well with the F70 on a 15.
TFrere
Postby TFrere » Wed Oct 02, 2019 12:11 am
I finally got the opportunity to go run my 1985 15 Sport with Yamaha F70 while alone in the boat.
Here are the particulars:
  • 2014 Yamaha F70 mounted two-holes-up
  • PowerTech SCD3 in 13.25 x 17
  • 9-gallons fuel, life jackets, a battery, a light tool box, mushroom anchor, spare aluminum prop, and me (200 lbs)
  • Trimmed up to optimize performance engine reached 6,300-RPM and boat speed reached 43-MPH at WOT
  • Speed measured with GPS
  • It gets a bit squirrelly so I didn’t stay WOT for long
  • Sweet spot is engine speed of 4,500-RPM and boat speed about 30-MPH.
El Rollo
Postby El Rollo » Wed Oct 02, 2019 10:18 am
Sounds like you've got that boat dialed in very well. The SCD-propeller seems to work very well with the Yamaha F70. You should be very happy with those results. Thank you for posting your findings.
TFrere
Postby TFrere » Wed Oct 02, 2019 6:03 pm
El Rollo wrote:Sounds like you've got that boat dialed in very well.
Thanks El Rollo. You’re right, I’m very pleased with the SCD3 17-pitch. I couldn’t have had a professional propeller technician dial-in the propeller more perfectly than it is now.
Postby biggiefl » Mon Oct 07, 2019 11:22 am
Congrats! That is the best performance I think I have seen on a classic 15 with a F70.
TFrere
Postby TFrere » Tue Oct 08, 2019 10:04 am
biggiefl wrote:Congrats! That is the best performance I think I have seen on a classic 15 with a F70.
Thanks Biggiefl. I’m satisfied.
rickster
Postby rickster » Tue Nov 19, 2019 10:08 am
I am in the process of buying a 1989 15ft, side console with a 2000 70hp Johnson. I noticed the motor is mounted on the lowest hole, what would you all recommend I raise it to for starters? It has a 3 bladed prop. Thanks!
Postby biggiefl » Tue Nov 19, 2019 10:23 am
You can go all the way up but try it one hole down from that. A 13x19 or 20" stainless prop should get you right at 6k full tilt boogie.
rickster
Postby rickster » Tue Nov 19, 2019 10:26 am
Thank you for the quick reply, I will check the prop this weekend, raise it one hole from the top and start there.
Postby biggiefl » Tue Nov 19, 2019 10:46 am
You can raise [the engine mounting height on the transom] with a friend and a block of wood. Put the wood under the skeg, remove the one set of bolts and loosen the other and use the trailer tongue jack to lower the transom.
