- a directional wattmeter;
- two adaptors to allow N-series and UHF-series connectors to mixed in the cabling;
- a short coaxial cable cable to allow the directional wattmeter to be inserted in the transmission line; and,
- a 50-Ohm dummy load to facilitate testing the transmitter power output into a proper load.
In addition, the advice offered very specific suggested products. I thought the selection of these four products was so very well chosen that I could not resist buying them, even though I already owned other instances of all of them. The recommended products were so particularly appropriate for the task of measuring VSWR at 156-MHz using a 25-Watt transmitter that they would be much more easily used than the gear I already had. So I spent about $100 on Amazon to buy them, as an early Christmas present to myself.
The four products had to sit in their boxes until just a few days ago when I got the chance to put them to use as intended: measuring the VSWR on my antenna with my 25-Watt radio. As anticipated, the four product worked beautifully together and made a compact and portable measuring system that could easily be carried to and used aboard boats.
Here are the details of each product and a link to Amazon.com where you can find them, as well as the current price:
DIRECTIONAL WATTMETER
Surecom SW-102 digital wattmeter, $58
125 to 525-MHz, 120-Watts maximum
N-series receptacle connectors
includes two adaptors, see below
https://www.amazon.com/dp/B01D86IKIQ
ADAPTORS
The two necessary UHF receptacle to N-type plug adaptors are included with the wattmeter.
SHORT CABLE
uxcell UHF PL259 to N-type male, 2-feet, $16
50-Ohm RG400 double shielded, silver plated, PTFE jacket
https://www.amazon.com/dp/B07VCYXBPQ?re ... title&th=1
For the cable specifications see http://www.rosnol.com/upload/product/RG-400%EF%BC%8F%EF%BC%B5.pdf
DUMMY LOAD
BECEN 25-Watt BC-TE25-1 500-Ohm Dummy load, $17
N-plug connector, 0 to 3-GHz Max. VSWR 1.2:1
https://www.amazon.com/dp/B08K2ZGYZ3
The original thread in which these devices were proposed was authored by a very knowledgeable guy going by the user-ID s/v Jedi on cruisersforum.com at
https://www.cruisersforum.com/forums/f1 ... ost3951595
I thought this would be a good place to share his recommendation and report on how well they worked together.
