Connecting a Yamaha Engine to NMEA 2000 Network
msteinkampf
Postby msteinkampf » Wed Dec 03, 2025 1:33 pm
JimH wrote:
"I can't offer any advice regarding a Yamaha engine and connecting it to a NMEA-2000 network. There seems to be some peculiarities associated with where you connect to the engine data depending on what type of Yamaha-brand instrumentation you already have. If you solve that puzzle and work out the various dependencies, as I am sure you will be successful at doing, a separate discussion on the topic "Connecting Yamaha engine to NMEA-2000 Network" would be very welcome. I don't understand what the mystery is about it, and I have not seen a good explanation of the why's and the wherefore's."
I accept this kind invitation, or perhaps it should be considered a challenge. There are indeed some peculiarities associated with connecting a Yamaha engine to an NMEA 2000 network; one can confirm this by performing Google searches on The Hull Truth Boating Forum (at https://thehulltruth.com), a boating and fishing discussion board that is said to be the largest of its kind, using the phrase “Connecting _________ engine to NMEA 2000 network”, filling in the blank with Mercury, Yamaha, or Honda. “Mercury” yielded about 1,000 results, while “Yamaha”, a brand with an approximately equal market share, gave three times that number. The search using “Honda”, a brand that probably has about one third the outboard motor market share of Mercury, yielded about 1/3 as many results. (Suzuki seems to be an outlier here - their engines require a proprietary adapter to output NMEA 2000 data, as does Mercury, but their system has led to more online discussions than any other brand when accounting for the (presumed) smaller numbers of engines sold. Many of the postings indicate that Suzuki has had problems with the firmware in their interface adapter.) I believe there is an explanation for these findings, but it might be best to start with a little background.
My first car, a 1962 Ford Falcon, had only one electronic device: a vacuum tube AM radio. Nowadays, the average automobile has 30 to 50 electronic control units (ECUs), with some luxury cars having as many as 100. As more complex automotive control systems were being developed, it became apparent that point-to-point wiring systems were not practical, so a German automotive engineering firm (Bosch) developed a communication protocol called Controlled Area Network (CAN) that greatly reduced the complexity of automotive wiring harnesses. A CAN bus (“bus” here meaning a system that carries electrical signals; it is typically a set of wires) allows ECUs to communicate with each other via a single wire loop without a host computer; it is simple, inexpensive, efficient, and extremely robust. Today, CAN systems have been developed for use in cars, trucks, tractors, buses, ships, planes, EV batteries, medical devices, and machinery. The current maritime CAN was developed by the National Marine Electronics Association (NMEA) in 2000, and the pieces of transmitted data are identified by a Parameter Group Number (PGN). For more details about the NMEA 2000 system, I recommend the excellent reviews to be found here; for a detailed discussion of the relevant connections involved, go here.
There are three other communication protocols of which boaters should be aware: NMEA 0183, an older, simpler, and slower maritime protocol; J1939, a CAN protocol from which NMEA 2000 was derived that was originally developed for heavy-duty vehicles; and Ethernet, a high-speed point-to-point protocol used for video transmission and the Internet. While NMEA 2000 is the most common protocol used in recreational marine equipment, some multifunction displays can communicate via other protocols. One unit I recently examined, a Garmin GPSMAP 943xsv, has connections for NMEA 0183, NMEA 2000, J1939, and Ethernet. Most of this narrative deals with NMEA 2000, but I will touch on some of the other protocols, too.
NMEA 2000 was designed to be a standardized plug-and-play system for connecting marine devices produced by different manufacturers, so why is there is so much discussion about the connection of a Yamaha outboard motor to an NMEA 2000 network? At first glance, the type of engine NMEA interface does not appear to determine the amount of online discussion. Mercury engines can connect to an NMEA 2000 network only by using a proprietary interface adaptor, or “gateway”, while Honda engines directly output NMEA 2000 information that can be accessed without any proprietary interface, and the PGNs sent by Honda's ECU are publicly available. As noted above, neither system has generated much online discussion. In contrast, Yamaha’s system is not so straightforward. Here is something I pulled from the Garmin ECHOMAP UHD2 6/7/9 2022 user manual regarding the display of engine gauge data on the ECHOMAP from Yamaha engines:
"For the best experience monitoring and controlling your compatible Yamaha engine or motor using this chartplotter, you must connect your engine or motor to the chartplotter using the appropriate interface adapter. If needed, contact your Yamaha dealer for more information."
Aside from the appearance of a proprietary screen format, the ECHOMAP manual does not indicate how one’s experience will be improved by using the Yamaha gateway.
Here is another revealing statement taken from the online Garmin Support Center (at https://support.garmin.com/en-US/?faq=0 ... U4vCHDgiA6):
“While some Yamaha engines may be able to integrate directly via NMEA 2000 without the use of a gateway, the installation itself is not something Garmin Product Support can assist with. It is possible that data displayed may be correct, provided the NMEA 2000 PGNs are supported by any networked chartplotters. For more information on supported NMEA 2000 PGNs, consult the Owner's Manual for the chartplotter. For information on how to accomplish this sort of install, consult with a Yamaha dealer.”
I suspect that much of the online discussion about NMEA 2000 connections to Yamaha engines is generated by owners who are trying to connect their chartplotters directly via a standard NMEA 2000 network without using Yamaha’s interface adapter (which currently sells for about $450 at SIM Yamaha). I have encountered eight different ways to get data from a Yamaha outboard motor to a Garmin chartplotter, but neither the Yamaha owner’s manual nor the service manual for the Yamaha F-70 mention NMEA 2000 connections, and the Yamaha rigging manual has a few diagrams with little explanation. This lack of information and support from Garmin and Yamaha has left some owners who work on their own boats struggling just to find the Yamaha NMEA plug, and I think it has contributed to the proliferation of online information and advice that is well-meaning but not always accurate. Here is one bit of misinformation from the continuousWave forum:
"Almost all modern outboard engines are certified for connection to a NMEA-2000 network. The only exceptions are Mercury Marine outboard engines." (from https://continuouswave.com/whaler/refer ... A2000.html)
If that were true, I probably wouldn’t be posting this narrative. There are no Yamaha engines that are NMEA certified. To my knowledge, Yamaha does not claim that the CAN data coming from their engines comply with NMEA standards. It’s Yamaha data, some of which include NMEA 2000 data. But don’t take my word for it, go to the NMEA website here and type in “Yamaha” to see which of their products is NMEA 2000 certified (only their CL7 display, which is made by Garmin). Of the gasoline-fueled outboard motor manufacturers currently represented in the United States, only Honda engines are NMEA certified (more precisely, it is the Honda engine's ECU that is certified; the engine management module (EMM) for Evinrude ETEC engines was also NMEA 2000 certified.) Please note that products listed as “NMEA compliant” or “NMEA compatible” may not meet the rigorous standards to which NMEA certified products are held. You can find Garmin's view of this matter here.
As if there wasn’t enough confusion about Yamaha NMEA connections, equipment manufacturers seem to have overlooked that the Yamaha F-70 can be connected to an NMEA 2000 system. Take a look at the Navico info (available for download from continuousWave here) on how to connect their devices to Yamaha engines, and you will see that the F-70 is not listed among the Yamaha outboards compatible with NMEA 2000; however, this is an error, as noted on the Yamaha F-70 hot sheet (at https://yamahamarinemedia.com/wp-conten ... tSheet.pdf). I have seen this omission in many other places online, so it is no surprise that some F-70 owners wonder whether their engines can be connected to NMEA 2000 devices.
Please don’t get me wrong; I think Yamaha and Garmin make excellent products, and I own both brands of equipment, but I think their corporate decisions have led to much confusion among owners, hence the “mystery”.
Next: Options for getting data from a Yamaha F70 outboard to a Garmin chartplotter.
Re: Connecting Yamaha Engine to NMEA 2000 Network
Postby jimh » Thu Dec 04, 2025 7:25 am
As SUZUKI was mentioned, I can contribute one bit of knowledge about connecting a SUZUKI outboard engine to a NMEA-2000 network:
While this may no longer be the case, in the beginning of using NMEA-2000 with outboard engines, the LOWRANCE displays were among the first--if not the first, to be able to show engine data. There was one peculiarity about the Lowrance approach to keeping track of fuel consumption: it was done in a separate, headless, small module (or dongle) sometimes called a memory module and later called a fuel data manager module, and not done in the display device itself.
In the factory guide for rigging the SUZUKI engines, the dongle or memory module or fuel data manager module was always provides as part of the interface cable that would connect the SUZUKI engine to the NMEA-2000 network, while in other brands the module was available as a separate part that would connect to the network backbone using the standard T-connector arrangement.
Getting back to Yamaha interfacing to NMEA-2000, I think the variation depends on whether the connection point available includes the two conductors for powering the network interface or if the power conductors are absent. This peculiarity is somehow related to what type of display device would be used. I suspect that if the display device required significant power to operate, then the network power circuit was not needed, but if the display device was relatively low power, it could run off the network power.
msteinkampf
Postby msteinkampf » Thu Dec 11, 2025 11:33 pm
The options for connecting a Yamaha outboard to a multifunction display (MFD) depend on what Yamaha engine(s) you have and which MFD you want it to connect to. I’m going to primarily discuss how to connect a Yamaha F70 engine to a Garmin ECHOMAP UHD2 93sv Fish Finder/Chartplotter Combo with GT54 Transducer, because that’s what I recently acquired, but I will touch on some other MFDs as well. Here is a photo of the back panel of my ECHOMAP.
Figure 1. Back panel of Garmin ECHOMAP UHD2 93sv.Note that there is a connection for NMEA 2000, but not NMEA 0183 – that feature was dropped when the unit was updated from the UHD to the UHD2 model.
ECHOMAP UHD2 connections low res.jpg (105.86 KiB) Viewed 6608 times
Option 1. Base Yamaha Support via Gateway - NMEA 2000 Integration Only
The diagram below is taken from the online Garmin Support Center article entitled “Supported Yamaha Features on a Garmin® Chartplotter” (available at https://support.garmin.com/en-US/?faq=0 ... U4vCHDgiA6). It shows a Yamaha Multi Hub connected to a Yamaha gateway that converts Yamaha information which can then be provided to the Garmin system via an NMEA 2000 bus. The Garmin article says “this installation provides engine data (Speed, Oil Pressure, etc.) and a Yamaha-specific User Interface”. Although documentation on the gateway is sparse, it appears that it translates some proprietary NMEA 2000 codes coming from the engine’s ECU so that they can be displayed by the Garmin MFD in a way that emulates a Yamaha CL7 screen. (The CL7 is an MFD manufactured by Garmin that is branded and sold by Yamaha.) If I had brought my boat to a Yamaha dealer with an ECHOMAP UHD2 93sv in hand and asked to have it connected to the engine, this is what I probably would have been offered. There is a Yamaha Multi Hub, which is Yamaha’s proprietary version of an NMEA 2000 bus, connected to a Yamaha NMEA 2000 gateway, which feeds into a generic NMEA 2000 bus that connects to the Garmin MFD. This setup would permit the use of Yamaha gauges or displays by connecting them to the Multi Hub while still allowing engine data to be transmitted to and displayed by the Garmin unit via the (generic) NMEA 2000 bus.
Figure 2. ECHOMAP connections to NMEA 2000 bus.
ECHOMAP NMEA 2000 bus.jpg (56.47 KiB) Viewed 6608 times
This diagram isn’t very realistic – note that a single engine is depicted, but the control shown is for two engines, and the MFD is displaying data for three engines. The throttle appears to be connected to the multi hub (which it is not, unless the throttle also contains an ignition key). Below is a diagram taken from a Yamaha Dealer Rigging Guide dated 2021 which shows the wiring between the gateway and the engine.
Figure 3. Connecting a Yamaha engine to an NMEA 2000 bus via a Yamaha Multi Hub and Gateway.
Yamaha gateway bus 1.jpg (74.07 KiB) Viewed 6608 times
This Yamaha diagram shows the connections between the gateway and the engine in greater detail than in the diagram supplied by Garmin. A Yamaha CL5 display (which I have circled in green) is shown connected to the Multi Hub, but for the purposes of this discussion it can be ignored. One might infer that these two diagrams could suffice as a guide for connecting the Garmin MFD to a Yamaha engine, but there are some problems here. Items 10, 11, and 13 are mislabeled, and there is an extra cap (item 9), but more importantly, power is being supplied at two different locations; if the power sources are not electrically isolated, they could cause devices attached to the buses to malfunction. It would make sense for Yamaha to include a power isolator in their gateway, but I have never seen this documented, so in this case a power isolator (not shown) should be installed between the two buses. Recall also that terminating resistors are required on the ends of an NMEA 2000 bus, whether it is generic or proprietary like the Yamaha Multi Hub. In these diagrams, the generic NMEA 2000 bus has terminators, but they appear to be missing from the Multi Hub. (Actually, only one resistor is missing, as there is a resistor incorporated into item 12, the single hub assembly.)
Next: More options.
M
msteinkampf
Postby msteinkampf » Fri Dec 12, 2025 2:38 pm
Option 2. NMEA 2000 using Yamaha gateway without the Multi Hub
For installations that don’t require a Multi Hub, Yamaha provides cables and adapters for connecting the gateway directly to the engine, as shown in the diagram below (downloaded from https://static.perfprotech.com/files/st ... ltihub.pdf) Note that some of the NMEA bus architecture (terminating resistors, switched power supply) is maintained.
Figure 4. Configuring the Yamaha gateway for NMEA 2000 data without using a Yamaha Multi Hub.
Yamaha gateway bus 2.jpg (51.64 KiB) Viewed 6603 times
Next: Accessing Yamaha NMEA 2000 data via Yamaha CL7 display
M
msteinkampf
Postby msteinkampf » Sat Dec 13, 2025 12:00 pm
Option 3. Accessing Yamaha NMEA 2000 data via the CL7 display
The Yamaha CL7 MFD was manufactured by Garmin and is similar to their GPSMAP 7607 unit, but the CL7 has a built-in Yamaha gateway and can output NMEA 2000 data to a generic NMEA 2000 bus. The CL7 connects to the engine via a Command Link bus using a Furukawa connector on the end of the power cable. Details of how the CL7 outputs the NMEA data are available in the CL7 installation and user manuals which can be downloaded here: https://global.yamaha-motor.com/busines ... e/cl7.html
(NB: It is my understanding that the Yamaha CL7 has been discontinued; only the the smaller CL5 display is shown in the Yamaha rigging brochure. The CL5 display does not have the capability to connect to an NMEA 2000 bus.)
Next: Options 4 and 5. Yamaha engine data access via Garmin J1939 port
M
msteinkampf
Postby msteinkampf » Mon Dec 15, 2025 5:40 pm
Option 4. “Advanced Yamaha® Support with J1939 Integration”.
Many Garmin GPSMAP chartplotters have a J1939 network port. This port allows the unit to receive J1939 sentences, some of which are comparable to NMEA 2000 data, from Yamaha engines using cables to connect a Yamaha Multi Hub directly to the chartplotter. Here is the diagram supplied by Garmin for this configuration.
Figure 5. Yamaha data via J1939 cable.
Garmin GPSMAP J1939 connection 2.jpg (51.04 KiB) Viewed 6582 times
According to Garmin, “The Yamaha Engine Bus to J1939 Cable solution uses a Garmin manufactured cable … fitted with a Yamaha pigtail connection that runs to a Yamaha Multi Hub engine bus. This installation provides the following: Engine data (Speed, Oil Pressure, etc.); Yamaha-specific User Interface; Send Waypoint data over J1939 to a Garmin MFD.” (taken from here: https://support.garmin.com/en-US/?faq=0 ... 4vCHDgiA60.) Details on how to accomplish this connection can be found here: https://static.garmin.com/pumac/Yamaha_cable.pdf.
A few points about this configuration:
1. A gateway is not required.
2. “Send Waypoint data over J1939 to a Garmin MFD” sounds like a misprint. With this configuration, Yamaha engine and diagnostic information is being sent via J1939, not navigation information.
3. The GPSMAP unit does not transmit over the J1939 network, it only receives, but the unit can also be connected to an NMEA 2000 network.
4. Some of the data coming to the J1939 port contain proprietary codes. Note the following statement taken from Yamaha J1939 to NMEA 2000 Bridging with Garmin Devices: “Yamaha engine data uses proprietary PGN sentences. The engine can connect to the Garmin chartplotter J1939 Port, but it is not J1939 data. It is Yamaha data. Garmin cannot act as a data bridge from Yamaha data to NMEA 2000 data.” (downloaded from here: https://support.garmin.com/en-US/?faq=c ... mXw9tjsvi7).
5. The Yamaha gauge page will display when an engine is connected to the J1939 port on the GPSMAP unit.
Option 5: “Full Yamaha® Support - J1939 Integration with MFD Interface”.
This configuration comprises a Yamaha Multi Hub that is connected via a J1939 cable to a Garmin GPSMAP as well as to a Yamaha MFD Interface (MFDI) black box that provides the following: Engine data (Speed, Oil Pressure, etc.); Yamaha-specific User Interface; Autopilot Controls (e.g. Heading Hold, Pattern Steer, etc.); Engine and Peripherals Control (Steering Friction, Trim, etc.); Technician Settings; and Send Waypoint data over J1939 to a Garmin MFD.
Figure 6. Yamaha data via MFD interface
GPSMAP J1939 connection 1.jpg (46.6 KiB) Viewed 6582 times
I believe this setup is meant to allow boat builders to install large glass MFDs which emulate the functionality of the Yamaha CL7 display. The MFD Interface (Type 1) is designed to work only with Garmin MFDs. Yamaha markets a similar unit (Type 2) which can be used with some other MFD brands.
Next: Displaying Yamaha NMEA 2000 data on a Garmin ECHOMAP without using a gateway
M
msteinkampf
Postby msteinkampf » Wed Dec 24, 2025 5:43 pm
Option 6. Displaying Yamaha NMEA 2000 data on a Garmin ECHOMAP without using a gateway
As noted above, Garmin indicates that their MFDs can receive NMEA 2000 data from “some” Yamaha engines without using a Yamaha Multi Hub or a Yamaha Gateway. Information supplied by Navico for their Lowrance MFDs states that neither a Yamaha Multi Hub nor a Yamaha Gateway is required for units to display NMEA 2000 data from a Yamaha engine. As far as I can tell, the only advantage of using the Yamaha Gateway is the ability to see the proprietary Yamaha display, which does provide some additional data such as alarm status, trouble codes, and a maintenance reminder. Some of the differences between the stock Garmin display and the Yamaha display are shown in this video, which was produced by Pursuit Boats: https://www.youtube.com/watch?v=0-fxBZFmKAI&t=178s.
For me to get the Yamaha display, it would cost more than $800 (the price of a Yamaha Gateway, Multi-Hub, and all required plugs, caps, and cables as shown in Figure 3, currently $805 from SIM Yamaha; add $25 for a Garmin power isolator), so I decided to try connecting my F70 engine directly to an NMEA network. Besides the NMEA backbone, this requires only a single item, the Yamaha Engine Interface Cable for NMEA2000), which has a 4-pin Furukawa plug on one end and an NMEA 2000 plug on the other. A 15-foot version of this cable that comes with an NMEA 2000 T-connector has been marketed by Lowrance for many years (currently at a price of $123), and it is now available from other online retailers. I bought a 16-foot version for $29 (https://www.amazon.com/dp/B0D69THD6W?re ... asin_title), figuring that the extra foot would be useful for the installation. (Keep in mind that the maximum length of a single drop cable like this one from the top of a T-connector to an NMEA 2000 device is 6 meters (about 20 ft).) I bought an Ancor NMEA 2000 starter kit (https://www.amazon.com/dp/B06ZZBXX69?re ... title&th=1); there are cheaper versions, but I felt more comfortable getting one labelled “NMEA Approved” from a wire manufacturer. According to Lowrance, this setup should provide the following information from a Yamaha 4-stroke 50-250 HP engine: RPM, Alternator Voltage, Engine Hours, Engine Temperature, [Fuel Pressure], Fuel Rate, [Oil Pressure], Trim, and [Water Pressure]. The bracketed items are not transmitted by the Yamaha F70 ECU (although there is an add-on kit available to obtain water pressure).
The installation is straightforward – connect one end of the interface cable to the Furukawa plug (the one with a blue and white wire) under the cowling, and other end to the NMEA 2000 backbone. Watch this YouTube video if you need more guidance doing this (https://www.youtube.com/watch?v=p5s_UUQRMsA). The hardest part for me was fitting the cable through the rigging grommet because I already had two cables from the hydraulic jack plate running through it. Here are pictures of the pertinent engine plugs:
Figure 7. Yamaha F70 NMEA 2000 plug (star), and trim plug (arrow). The NMEA plug protector must be removed to connect the interface cable. The tape and plug protectors should be removed from the trim plug and the two connectors joined to allow trim data to be displayed on the MFD.
Yamaha NMEA and trim plugs low res.jpg (237.79 KiB) Viewed 6558 times
Figure 8. Yamaha NMEA 2000 Furukawa plug. Note that only two of the four pin positions are used. The white trim plugs with yellow tape are in the background.
Yamaha NMEA plug low res.jpg (88.85 KiB) Viewed 6558 times
Next: Testing the system.
M
msteinkampf
Postby msteinkampf » Wed Dec 24, 2025 6:30 pm
After connecting and initializing the Garmin Echomap, I powered up the NMEA 2000 backbone and turned the engine's ignition switch only to be greeted with a loud beeping and an error code displayed on the MFD.
Figure 9. Initial engine display.
Garmin Echomap initial picture.jpg (81 KiB) Viewed 6557 times
Actually, there were four alarms activated, as seen here.
Figure 10, Garmin status alarms activated on initial start-up are highlighted in orange.
Garmin Echomap status alarms.jpg (78.45 KiB) Viewed 6557 times
This was not unexpected; Garmin units are known to interpret some proprietary Yamaha codes as alarms. To clear these, one must tap on the three dots at the lower right of the home screen, then tap on Status Alarms -->Custom, and scroll down to the activated alarms, which will be highlighted in orange. Toggle each alarm to "off", and then exit. After that, the MFD displayed all the data as expected. Here is the screen I settled on for now, although I will probably modify this in the future with further use. I am satisfied with the outcome of this installation.
Figure 11. Final MFD engine screen.
Garmin Echomap final picture.jpg (75.83 KiB) Viewed 6557 times
M
Postby jimh » Sun Dec 28, 2025 8:16 am
Thank you for the very interesting series of articles on the Yamaha to NMEA-2000 interface options.
I notice that in the network connection point there are only two wires, which must then be the data circuit. This means the network power circuit is not connected to the Yamaha devices.
Generally in NMEA-2000 the network power circuit is continued to and connected to any devices on the network, in order that the network interface device will be operating from network power. And in the case of some headless small devices (such as a fuel manager or an interface convertor) the attached device will operate from network power, as typically those small devices have no other power connection provided.
The NMEA-2000 network electrical protocol is derived from the CANBus protocol. The CANBus protocol requires that each network device use an isolated power connection to the network in order to avoid introducing ground loops into the bus power. There is a technical discussion of the CAN interface as used in NMEA-2000 at
https://ttlappalainen.github.io/NMEA200 ... et_up.html
Without knowing exactly how Yamaha has implemented their NMEA-2000 interface, it will not be possible to understand if their device follows the protocol for maintaining power isolation or now. On the basis that it works and does not actually make an electrical connection to the network bus power circuit, one can presume it is operating in accordance with the NMEA-2000 protocol--but it still seems to be an outlier in terms of most other NMEA-2000 devices where the power circuit is carried to the device at the point of connection to the network backbone bus.
msteinkampf
Postby msteinkampf » Sat Jan 03, 2026 4:12 pm
A few additional points:
- My Garmin unit displays a datum accompanied by the symbol for “boost pressure”, the additional pressure supplied by a turbocharger or supercharger to the air intake manifold. In a normally aspirated engine like the F70, this is the absolute pressure at the air intake manifold, which is atmospheric pressure when the engine is off, and somewhat less when the engine is operating.
- I previously suggested that there were at least eight ways to connect a Yamaha engine, but I only discussed six. Here are the other two:
Option 7. Use the Lowrance Yamaha cable to connect the engine to a standard NMEA 2000 bus and use a drop cable to connect the bus to a Garmin GPSMAP J1939 port. This is said to obtain the Yamaha proprietary display. I have no personal experience to confirm this.
Option 8. Obtain NMEA 2000 data from engine analog ouputs. I found three products that are marketed to convert analog engine and sensor data to the NMEA 2000 format:
Actisense EMU-1 (https://actisense.com/emu-1-custom-gauge-manager/)
NoLand RS-11 (https://nolandeng.com/product/rs11-canb ... converter/)
Albatross AlbaCombi (https://www.albacombi.com/)
Here is some verbiage from one of the manufacturers:
“The Actisense EMU-1 is a specialized analogue to NMEA 2000 Gateway which converts data from analogue engine gauges/senders into NMEA 2000 data. The EMU-1 enables the sharing of engine data throughout the NMEA 2000 bus. It digitises analogue engine sensors, enabling NMEA 2000 display devices to monitor the connected engine(s) on a vessel. The EMU-1 can monitor vital engine parameters such as temperature, pressure RPM and fluid levels from up to two engines. NOW INCLUDES SUPPORT FOR TILT & TRIM TABS!”
- Researching a topic about which so much of the information is proprietary was a daunting task. The best information I could obtain without cost from the NMEA came from a presentation given by their technical director more than 15 years ago (available here: https://web.nmea.org/External/WCPages/W ... tentID=391). Online searches yielded hundreds of unhelpful posts by owners struggling to set up their systems. I found it most productive to review the online contributions of “fwpratt”, a Yamaha outboard owner based in Florida who seems to be particularly knowledgeable about NMEA 2000 systems.
M
Re: Connecting a Yamaha Engine to NMEA 2000 Network
Postby jimh » Sun Jan 04, 2026 11:29 am
Thanks for finding that old NMEA organization presentation. I will add it to my collection of documentation of the NMEA-2000 protocol in the REFERENCE section.
I remember reading that document many years ago. Like many other high-information content articles that NMEA used to have available, it's very hard to find that information in 2026.
Also, I have added a link to your outstanding information content that appears in this thread to the list of information available about connecting Yamaha outboard engines to a NMEA-2000 network in the above linked REFERENCE section article.
msteinkampf
Postby msteinkampf » Sat Jun 27, 2026 7:37 am
A final note about connecting a Garmin ECHOMAP UHD2 93sv to a Yamaha F70 outboard motor:
The setup for the Garmin unit includes designating the number of engines, and I initially chose “1”. When I ran the boat, the fuel economy readout was blank, but when I reset the number of engines to “Auto Configure”, fuel economy was displayed. I have since had to punch the “Reset Auto Configuration” option on the Engine Selection menu to get the data to reappear after the boat sat idle for a day.
Figure 11. “Auto Configure” may need to be selected for fuel economy data to appear.
ECHOMAP setup 1 June 2026.jpg (61.67 KiB) Viewed 3554 times
Figure 12. If Auto Configure has been previously selected but the fuel economy data has disappeared, selecting “Reset Auto Configuration” may cause it to reappear.
ECHOMAP setup 2 June 2026.jpg (59.24 KiB) Viewed 3554 times
M
