1989 OUTRAGE 22 Engine Bracket
Salty1966
Postby Salty1966 » Wed Dec 31, 2025 12:02 pm
[Where can] information on outboard engine brackets for a 1989 OUTRAGE 22 [be found].
[Moderator's note: this post was appended to a topic on a different subject which had been dormant for about 30-months. Please do NOT revive dormant topics only to change the topic of the discussion to a different topic. Also, remarks in the original post which asserted that the author "apparently" did not have the ability to create a new post have been removed, as the author did create a new post, which was appended to the old thread. Please note that in order to have the option to create a new topic or new thread, you have to post from the INDEX page of a forum. Once you enter an existing thread, the option to create a new topic is not available.]
Re: Information on 1989 OUTRAGE 22 Engine Bracket
Postby jimh » Wed Dec 31, 2025 1:24 pm
I don't see anything about outboard engine brackets that would make them have specificity to, that is, to uniquely apply only to an 1989 OUTRAGE 22. Unless you can inform readers of something uniquely specific about a 1989 OUTRAGE 22 boat that would cause general information about engine brackets to have limited value when applied to an 1989 OUTRAGE 22 hull, I think you would benefit from a reply that offers general advice. In that realm, try reading these articles in the REFERENCE section:
Engine Brackets
https://continuouswave.com/whaler/refer ... ckets.html
Standard Transoms and Brackets
https://continuouswave.com/whaler/refer ... acket.html
PRIOR DISCUSSIONS
In the new forum archives there are only two posts in which the search terms "engine" bracket" "outrage" "22" ALL OCCUR--and those are the two posts in this thread.
In the new forum archives there are 90 posts in which the search terms "engine" bracket" "outrage" ALL OCCUR. If you would like to locate those posts here is a link to the search that will find them:
https://continuouswave.com/forum/search.php?keywords=Engine+%2B+bracket+%2B+OUTRAGE+%2B+22&terms=all&author=&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
In the old forum you can find archived discussions using the terms "engine" "bracket" "outrage" with this search:
https://www.google.com/search?q=engine+ ... .com%2Fubb
Also, it will be helpful to readers in formulating a reply to your request for information if you gave more information about the particular type of outboard engine bracket about which you are interested in learn information.
For example, please note which of the below characteristics of the bracket are important to you:
  • raising engine mounting height;
  • increasing engine distance from transom;
  • ability to adjust engine height during operation of engine;
  • presence of a buoyancy box to compensate for weight;
  • construction materials, such as aluminum or molded fiberglass;
  • cost;
  • weight;
  • brand.
Further, please explain what you expect to accomplish, that is what improvement is anticipated, from using an outboard engine bracket on a 1989 OUTRAGE 22?
