Common Hull Defects in a 1986 STANDARD 13
liam_batch
Postby liam_batch » Mon Apr 13, 2026 11:23 am
Q1: what hull defects should I look for in a 1986 STANDARD 13?
I have an opportunity to purchase a 1986 STANDARD 13 that from photographs looks to be in good shape. It has a a 20-HP engine.
Re: Purchasing 1986 13ft Standard Model what to look for
Postby jimh » Tue Apr 14, 2026 9:08 am
Please visit the REFERENCE section and read the entire FAQ answers. The FAQ answers will give you a good base knowledge of the most common problems encountered with Unibond hull construction used on all Boston Whaler boats.
Frequently Asked Questions
https://continuouswave.com/whaler/reference/FAQ/
Re: Common Hull Defects in a 1986 STANDARD 13
Postby Jefecinco » Tue Apr 14, 2026 10:27 am
The quick and dirty test of too much water in that small hull is to put the boat in the water to determine how well it floats on its lines. Of particular interest are the two stern deck drains. If they are underwater that indicates that the boat may not be an acceptable candidate purchase.
A 20-HP engine will not push the boat well.
There are a lot of nice 13-footers for sale.
