The previous owner was an older gentleman who didnt really care to go fast, though he had repowered with the current outboard. He sold me the boat with two propellers.
- Black Max three-blade 13-inch x 19 pitch, and I believe this is what the boat was re-powered with. It wasn’t on the boat when I purchased the boat. The seller said he had hit something with it and had it repaired, but he was just using the spare he had bought instead.
- Turning Point Hustler four-blade 13.25-inch x 17 pitch, which came on the engine.
- I have since borrowed and tried a third propeller which is a Black Max three-blade 13.75-inch x 15 pitch.
Performance of the three propellers has been has follows, and none I believe are the “right” prop for the boat:
Turning Point 17 pitch: 38-MPH at 5400 RPM with two people, 10 gallons of fuel. Fully trimmed out -
Black Max 15 pitch: 38 MPH at 6000 RPM with two people, 10 gallons of fuel. Hit RPM limiter well before WOT
Black Max 19 pitch: 41 MPH at 5250 RPM with one person and 8 gallons of fuel. Boat handling was very weird with this propeller, best I can describe it is squirrelly and unsettled. I couldn’t trim up very much without the propeller blowing out and the engine speed immediately jumped but boat speed didn’t. I trimmed down and engine speed dropped and boat speed increased.
Before I go propeller hunting I figured best to poll the general knowledge of this forum. I can take information gathered here to a local propeller shop to try to work out what is best.
I am thinking of either going for a Black Max three-blade 16 or 17 pitch or a Spitfire four-blade 15 or 17 pitch (and likely the aluminum one, not sure I am ready to fork over for a steel propeller, though there is a 17 pitch used one near me for $450).
I actually bought two used props: a 17 pitch Black Max and also the 15 pitch Black Max since they were a good deal. The 17 pitch broke a blade tip when i went to install it, and come to find out it had been repaired.
My performance goals:
- Get the WOT engine speed to be between 5800-6000 when lightly loaded.
- Max speed is less important, I don’t feel like I need to go much more than 40-MPH based off my use to date.
- Accelleration is more important. I will be pulling kids on a tube. I’ll probably hold on to the Black Max 15 pitch for those times since it spun up well.
Thanks for your help
