1992 23 WALKAROUND Fuel Gauge and Sender
whalerguy
Postby whalerguy » Tue Jul 26, 2016 9:32 am
Recently replaced the gauge and sender [on a 1992 Boston Whaler 23 WALKAROUND boat], as the originals were giving readings less than empty when ignition was turned on. Wiring was replace and new sender and gauge were replaced. I received a correct reading upon turning the ignition and now getting reading below empty again. There is approximately 3/4 tank of fuel.
Any thoughts?
Thanks
Re: 1992 23 WA Fuel gauge/sender concern
Postby Phil T » Tue Jul 26, 2016 1:07 pm
Check all the wiring connections.
Check the float on the arm.
Re: 1992 23 WALKAROUND Fuel Gauge and Sender
Postby jimh » Wed Jul 27, 2016 9:11 am
The electrical meter should never go below the ZERO point. If it does, the polarity of the meter is wrong.
