1997 21 Outrage Trailer
nwwhalerguy
Postby nwwhalerguy » Fri Mar 17, 2017 4:01 pm
[What] size and type trailer is needed for a 1997 21 OUTRAGE? Any help is appreciated.
Re: 1997 21 Outrage Trailer
Postby jimh » Fri Mar 17, 2017 4:32 pm
I don't have reason to believe there is anything particularly unique to or special about a 1997 21 OUTRAGE boat. The bare hull is 2,500-lbs, so I'd anticipate with engine, fuel, and gear the boat will weigh almost 5,000-lbs. I'd get a trailer with tandem axles and brakes on all four wheels. Recommendations for trailers for Boston Whaler boats are given in
There are six lengthy articles on trailer selection and use which should inform you before you buy a new trailer.
If the trailer will be used frequently in saltwater, invest in upgrades to the trailer to reduce corrosion problems, such as stainless steel fasteners, flushing hoses for wheels and brakes, and upgraded brake components.
I have been using an E-Z-LOADER trailer (an older model that is similar to a TEZ-19-22/24 5200-lbs model) for many years for my classic REVENGE 22 W-T WD boat. The trailer is on its third set of tires and has more than 40,000-miles of hauling in the past ten years or so. Find more E-Z-LOADER specifications at
http://www.ezloader.com/images/pdf/adj- ... ations.pdf
Boat trailer sales are often quite localized. Check your local area to see what is available. Nationally-distributed brands are generally good choices, but often local manufacturers make good trailers, too.
nwwhalerguy
Postby nwwhalerguy » Fri Mar 17, 2017 11:53 pm
Thanks jimh,
That was precisely the information I was looking for.
underbone
Postby underbone » Sun Mar 19, 2017 9:06 pm
You can't go wrong with E-Z-Loader. Lots of folks around here use them without any major problems.
msirof2001
Postby msirof2001 » Mon Mar 20, 2017 11:36 am
When I had a trailer for my 1995 OUTRAGE 21 which has the same dimensions and weight as the 1997, it matched everything in JimH's description. The boat was close to 5000lbs loaded. I had a Pacific Trailer. They are located in Chino, CA. It was galvanized, had stainless steel fittings, heavy-duty brakes, dual axles. I also had carpeted bunks. On the sides, I had a carpeted rail which helped guide the boat onto the trailer. Great for 1-person launch and retrieval.
