Water In Hull via Drain Tube
Rags
Postby Rags » Fri Apr 21, 2017 5:14 pm
After reading about Boston Whaler hull containing water I got worried. The boat [I] am restoring has a loose drain tube and contains some water.
Is there a secondary seal behind the drain tub? As like a coating off some sort?
Re: Water In Hull
Postby jimh » Fri Apr 21, 2017 7:59 pm
RAGS--what is a "drain tub"? Do you mean the engine splashwell?
Rags
Re: Water in Hull Via Drain Tube
Postby Rags » Sat Apr 22, 2017 12:16 am
I am worried that the hull might contain water as the drain tube is loose. Is the drain hole [double] sealed, as in [is it] coated or sealed beyond the tube[?]
Re: Drain Tube Sealing
Postby jimh » Sat Apr 22, 2017 9:19 am
OK, I think "drain tub" was supposed to be "drain tube." Now your question makes more sense.
No. When the hole is made through the hull for the drain tube to pass through, there is typically nothing applied to the exposed foam between the inner and outer hull. If the drain tube becomes unsealed at either end, then water can enter the opening.
Re: Water In Hull via Drain Tube
Postby jimh » Sat Apr 22, 2017 11:45 am
For more information about drain tubes and replacement drain tubes, see the answer in the FAQ at
http://continuouswave.com/whaler/reference/FAQ/#Q12
If you are new to Boston Whaler boat repair, read the entire FAQ. It contains a lot of useful information.
