1996 Outrage 24: Fabricate Replacement Plexiglass Chart Cover
moparharn
Postby moparharn » Thu May 25, 2017 10:46 am
My 1996 Outrage 24 is missing the smoked plexiglas chart cover that goes over the right side of the console next to the wheel. I believe it has two bends in it to allow it to fold over the edges of the console. Can anyone who has their cover PLEASE give me some measurements so that I can get one made. I called Whaler and they said the vendor went out of business and referred me to Beacon Marine. Sue at Beacon has offered to get it made if I can get some measurements. Any help would be appreciated. Thank you! Bill
Re: 1996 Outrage 24: Fabricate Replacement Plexiglass Chart Cover
Postby Phil T » Thu May 25, 2017 11:57 am
In case you don't get any responses, you can fabricate up a template using cardboard or fiberboard and then do the measurements from that.
Do you need help on what it looks like? Here is one from a 1994 Outrage 24
IMG_9381 (Small).jpg (40.8 KiB) Viewed 8002 times
Postby Phil T » Thu May 25, 2017 12:01 pm
Here is a photo showing the front lip from a 1997.
moparharn
Re: 1996 Outrage 24 Vintage- Need owner help.
Postby moparharn » Thu May 25, 2017 12:46 pm
Thank you! That is very helpful. It looks like it has no fold forward and is folded down on both sides, while the rearward portion folds down to possibly hand over the switches so that any water might run down aft of the switches to keep them drier? Mocking one up from cardboard is a great idea. Thank you for the solid advice. Bill
Postby jimh » Thu May 25, 2017 1:17 pm
Phil's recommendation to mock up a replacement cover with cardboard is a great idea.
Making a replacement from Plexiglass should not be too hard--it could even be a do-it-yourself project if you are adventurous. Depending on where you are located and the size of your town, you might be able to find a local fabricator that can work with Plexiglass. Look for a "display shop" or place that makes custom signs or point-of-sale displays. That sort of shop will know how to cut, polish, then heat and bend clear plastic sheets to make your replacement.
You could also re-design the cover slightly and let it have wooden sides. It would be a way to get a bit of teak or mahogany on that console.
NLA01
Postby NLA01 » Tue May 30, 2017 9:31 am
I can run by storage this week and try to get measurements for you. It looks to be 1/4" plexi glass. and the are some funky angles but I will do my best.
Archie
Pinion
Postby Pinion » Wed May 31, 2017 10:08 am
You can still purchase a direct replacement of these. They arent cheap, but you're not going to go broke getting a new one.
Postby jimh » Thu Jul 20, 2017 9:59 am
The REFERENCE section article on OEM SOURCES and RECOMMENDED VENDORS provides guidance on replacement windshields and recommends UPD Plastics. See
http://continuouswave.com/whaler/refere ... indshields
As PINION notes, UPD Plastics does sell replacement chart covers. They are $75. See "Boston Whaler 1996 24ft Outrage Chart Cover" on their website page (mentioned above by PINION) at
https://www.updplastics.com/windshield- ... ndshields/
