2007 DAUNTLESS 220 Bow Rail Removal
Dallen9975
Postby Dallen9975 » Sun Sep 03, 2017 2:44 pm
I'm thinking of removing the bow rail on my 2007 Dauntless 220. [Do you have] any thoughts and advice?
What is to be done with mounting holes?
[Are there any images of a] Dauntless with rail removed?
Any clever solutions like added hand rails for bow passengers? Cup holders?
Thanks
Re: 2007 DAUNTLESS 220 Bow Rail Removal
Postby jimh » Sun Sep 03, 2017 3:01 pm
My general thoughts and advice about making any modification to a Boston Whaler boat: give it careful thought, as not every modification is a real enhancement, and some end up looking like hacks.
If you completely remove the railings there will be many fastener holes left to be filled, faired, top-coated with matching gel coat, and blended into the deck--and this takes an artisan's touch to do properly. Are you a gel coat artisan?
Postby Jefecinco » Sun Sep 03, 2017 7:36 pm
Is your goal to install a trolling motor?
Dallen9975
Postby Dallen9975 » Sun Sep 03, 2017 8:32 pm
Thanks guys. Definitely not an "artisan", though one can be hired if needed.
I've researched photos of the boat without the bow rail which was apparently a factory "delete option", so it's not a crazy modification and looks much more modern.
I will not be installing a trolling motor but I see where you were going with that, good thought.
myakka
Postby myakka » Tue Sep 19, 2017 6:40 am
I've seen one locally that had round pieces of stainless and holes for the screws for each of the rail attachment locations.
Dallen9975
Postby Dallen9975 » Tue Sep 19, 2017 7:14 am
That's a great idea!
Postby Phil T » Wed Sep 20, 2017 7:49 am
Buff out the area so it blends. Reinsert the screws into the holes with a dab of marine sealant under the head.
I would save the rail for at least a year to ensure you really like it off. It is a hard thing to sell and even harder to buy.
Dutchman
Postby Dutchman » Wed Sep 20, 2017 8:50 am
Dallen9975 wrote:What is to be done with mounting holes?
Answered several times above
Easy to do with your boat. Take a picture of your boat and use a photo editing software to remove the railing. Ask one of the kids --I laugh aloud-- they'll do it in a flash.
Any clever solutions like added hand rails for bow passengers? Thanks
You could have lower 3"-4" high grab-rails made with the same stanchion mount locations by a local fabricator either out of stainless or maybe wood.
Personally I think your model looks good with the railing and its added use, security, and safety is nice to have.
Show us the pictures after you made the modification(s)
EJO
