90 Degree Rail Tee
dg22
90 Degree Rail Tee
Postby dg22 » Wed Mar 28, 2018 10:17 am
Hi, I need to buy two 90-degree rail T's for my 1967 SPORT 13. I believe the original rail is 7/8". The T needs to slide on from the end, through the curve, and then fitted in the middle of the rail.
Do I need the 7/8" T or the 1" T?
It may sound like an obvious answer but my concern is when sliding on will the 7/8" one get stuck in the curve of the rail?
This is the Tee I'm looking at from a local shop.
https://riggingshoppe.com/collections/rail-fittings/products/7-8-stainless-steel-90d-tee
Re: 90 Degree Rail Tee
Postby jimh » Wed Mar 28, 2018 7:42 pm
You may need split T fittings.
dg22
Postby dg22 » Wed Mar 28, 2018 8:36 pm
Jim, what is the difference between a T fitting and a split T fitting?
Postby jimh » Thu Mar 29, 2018 8:31 am
A split-T fitting is a two-piece fitting that assembles onto the railing.
dg22
Postby dg22 » Thu Mar 29, 2018 8:56 am
That will work perfectly. Thinking back, I believe the original was a split T but it was so corroded I had to remove. I temporarily (for 8 years) used a plumbing T.
