PATE Fuel Tank Replacement
Montauk2003
Postby Montauk2003 » Fri May 18, 2018 5:33 pm
Hi fellow boaters.
I need to replace a PATE 27-gallon on-deck fuel tank used on a 2003 170 Montauk. What will be a good substitute?
Will a Moeller 22-gallon tank (UPC739729011454) slide in without any modifications or lifting the seat on a 2003 170 Montauk?
Danny
Re: PATE Fuel Tank Replacement
Postby jimh » Sat May 19, 2018 9:00 am
Please give the dimensions of the available space. Please give the dimension of the new fuel tank you may buy.
Postby Phil T » Sat May 19, 2018 12:53 pm
If you are referring to this tank: https://www.westmarine.com/buy/moeller--22-gallon-white-above-deck-fuel-tank--11052461, the answer is...yes it fits without modification.
Montauk2003
Postby Montauk2003 » Sat May 19, 2018 9:54 pm
jimh wrote:Please give the dimensions of the available space. Please give the dimension of the new fuel tank you may buy.
The PATE was 30" long x 19" deep x 14" high. Looks like the Moeller 22 gallon should be fine.
Danny
Montauk2003
Postby Montauk2003 » Sat May 19, 2018 9:55 pm
Phil T wrote:If you are referring to this tank: https://www.westmarine.com/buy/moeller--22-gallon-white-above-deck-fuel-tank--11052461, the answer is...yes it fits without modification.
Hey Phil. That is the one I ordered.
Danny
