Repair of Damage to Gel Coat Layer on Hull Bottom
roguewave
Postby roguewave » Sun May 27, 2018 4:57 pm
I wasn't paying attention and ran the boat onto on some submerged rocks--at slow speed, thankfully. Until I pulled the boat off the grinding was disheartening.
After siting at the dock in saltwater for a couple days, I pulled the boat. I saw some gouges on the bottom. One spot is the size of a pencil eraser. I can see some dark color--fiberglass, I guess.
Give suggestions on the repair procedure. Is a repair even necessary?
Thanks.
..."some gave all, KIA"...
Re: Repair of Damage to Gel Coat Layer on Hull Bottom
Postby jimh » Sun May 27, 2018 5:32 pm
If the gel coat layer has been abraded away and the underlying laminate layers are exposed, a repair should be made.
Because the damage is on the hull bottom and will be perpetually underwater when the boat is in use, a repair is necessary. The gel coat layer is considered a water-resistant layer, but the underlying laminate layers are not water resistant. As the repair generally will not be visible, making a completely perfect cosmetic repair won't be mandatory.
For advice on how to make minor repairs to a Boston Whaler, there are three good articles. Here are the links.
The Epoxy Cure
by Jim Hebert
by Boston Whaler
http://continuouswave.com/whaler/reference/repairInstructions.html
by Taylor Clark
http://continuouswave.com/whaler/reference/whalerRepair.html
roguewave
Postby roguewave » Sun May 27, 2018 8:45 pm
Thanks Jim
