190 Nantucket Live Well Pump: Repair or Replace
InVision
Postby InVision » Mon Jun 04, 2018 10:27 am
The live well pump [on a 2004 190 NANTUCKET] has died. The circuit breaker [trips opens] when turned on. [The circuit] has power so I think [the cause of the circuit breaker faulting] is just [a dead pump]. [Give me] suggestions to replace, to repair, or to get a different pump.
Currently the pump is a ShurFlo Bait Sentry 500. If I replace it I may get a 800 or 1100. The live well seemed to need some more flow.
Thank you
M
Boat Photos
Re: Nantucket Live Well Pump Repair or Replace
Postby jimh » Mon Jun 04, 2018 12:05 pm
To verify that the cause of the circuit breaker faulting is from the pump, disconnect the pump from the circuit near the pump and retest. A problem in the wiring between the pump and the circuit breaker could also cause the breaker to trip open.
If the pump is the cause, I doubt there is much possibility for repair for the pump. Replacement seems likely the best way to remedy a problem in the pump.
InVision
Postby InVision » Mon Jun 04, 2018 1:19 pm
Exactly how I tested it. On the bench it did the same thing. I figure a bait well pump lasting 14 years is good.
Is there something I am overlooking by going to a Bait Sentry 800 instead of the Bait Sentry 500?
Thanks
M
Boat Photos
InVision
Re: 190 Nantucket Live Well Pump: Repair or Replace
Postby InVision » Mon Jun 04, 2018 2:40 pm
Also the inline valve is plastic from the bronze thru hull. It does not work, just slips, does not open all the way, and does not close all the way--replacing with a bronze ball valve. Why did Boston Whaler use plastic on thru-hull rigging? All the boats I have owned always used bronze. Pretty cheap from Boston Whaler.
M
Boat Photos
InVision
Postby InVision » Sat Jun 09, 2018 11:02 am
For the record I installed a 800 Bait Sentry and Bronze Shut off valve. I also replaced the 2amp breaker with a Blue Seas 5amp as directions indicated. Got plenty of pressure in the well and my plan is to install a two way valve in line and put a raw water spray hose in engine well.
M
Boat Photos
