1968 13-footer Oar Lock Repair
douginport
Postby douginport » Tue Jun 26, 2018 7:46 pm
On a 1968 Boston Whaler 13-footer, one of my kid's friends tripped over a partially inserted oar and tore the bronze receiver right out of the gunwale.
I have contacted Caplugs, the gunwale insert manufacturer, no luck yet
I might 3-D-print one if I can get good measurements from the parts.
The insert prevents the oar yoke from getting water into the hull.
Has anyone ever fixed one of these before?
Any insight would be appreciated.--Doug
Oarlock break-out at gunwale, part way through foam removal.
gunwale 1 sm.jpg (43.41 KiB) Viewed 6520 times
Profile view of oar lock insert: Caplugs # B-178
Caplugs profile sm.jpg (50.34 KiB) Viewed 6520 times
End cap with manufacturer and model # of oar lock insert
Caplugs end sm.jpg (19.1 KiB) Viewed 6520 times
ConB
Re: 1968 13-footer Oar Lock Repair
Postby ConB » Tue Jun 26, 2018 9:25 pm
West system epoxy with fillers.
And here is a new socket if you need one.
https://www.jamestowndistributors.com/userportal/show_product.do?pid=298
Con
1969 13 / 30hp Johnson tiller
Meaty
Postby Meaty » Wed Mar 25, 2020 11:36 am
I’d like to install oar lock sockets on my 13-footer.
[Where can a] replacement mold be purchased?
[What are the] measurement to location of socket?
[Give me] any other useful information about materials and process.
Thanks.
Meaty
Postby Meaty » Wed Mar 25, 2020 11:42 am
I called CARPLUGS. They will make them [that is, I presume, the molded insert that goes into the open oarlock to prevent intrusion of water into the hull as seen above in the initial discussion--jimh] for only $0.19-each. The problem is 5000 pieces minimum order.
Postby jimh » Wed Mar 25, 2020 11:46 am
Meaty wrote:[Where can a] replacement mold be purchased?
If you are trying to mold your own oarlock plugs, why can't you use the oarlock itself as the mold?
Meaty
Postby Meaty » Sun Mar 29, 2020 4:27 pm
True. Probably over thinking it. But I’m now thinking about side mount sockets. I think they will go about 11-inches from the gear locker seat. Based on the wood locating diagram I don’t think there is any wood in that location.
Will a side mount oarlock installed where there is no imbedded wood support be strong enough?
Postby biggiefl » Mon Mar 30, 2020 11:03 am
Do you row this boat? Are there not 2 sets of oarlocks? Reason I ask is you would not usually be rowing while sitting at the front of the boat, most likely use the aft set of oarlocks. I would fill them in personally.
Meaty
Postby Meaty » Fri Apr 03, 2020 1:06 pm
I believe some whaler 13 have one set of oat sockets. Was an option on some models. Rower sits on gear locker.
Postby biggiefl » Fri Apr 03, 2020 1:46 pm
I am assuming the gear locker is the bow locker up front that holds your lines, etc.
Again I would not row from that position unless you had a heavy person in the rear. Not sure about my old 13 as I did have a 9' Squall first and one, if not both, had 2 sets of oar locks.
